Hello, i would like to buy two flashlights with different pourposes.
- First one should be a compact, everyday use flashlight, to keep into the pocket or into the car closet. The budget is about 30€. For this one, i’ve searched into this forum and found that probably the Sofirn SC31 Pro is a good option and can be found for less than 20€ (but loooong shipping time….). My main doubt is colour temperature, 500K vs 6500k. Do you think that this model can be a good choice? Which colour temperature should be better, considering that the standard use will be mainly outdoor, into countryside environment?
- Second one should a light with a good throw but also quite wide beam, for long range survellaince purposes around the house (we live in the countryside), mainly to spot feral animals that regularly come into the fields which surround the house and make dogs burk. This torch can be bulkier than the first one and possible should be more powerful. It will be kept into the house and should be simple to use as will be basically used by my parents. To give an idea of the desired type,this torch will be the substitue of this B&D one (model BDSL302) that stopped working:
The budget for this one is around 50€. I’ve seen that Sofirn makes other good models (SP36 Pro, SP70….) but i can’t figure out which one will fit better for my purpose. Other model, brand suggestions are welcome, especially if they have a shorter lead time.
Thank you ![]()
