Hi, folks!
The time has come for me to acquire full sized, high quality multi tool for some up to heavy duty tasks!
My main choice at the moment is either black/regular ST300 or Rebar+Micra combo, both will cost around the same, single black Rebar is also not out of question, but given that for the price of combo Im basically getting Micra almost for free its not my top option.
My main concern is the size and usability of pliers.
Ive seen comparisons between Leatherman’s and it seems that pliers on ST300 are quite a bit bigger, actually the biggest ones so far and thus most likely more robust and usable on bolts/screws due to bigger surface of pliers/bigger jaws?
Does any one of you here owns both - Rebar and ST300? If so, Id like to see side-by-side comparison pictures of their pliers as well as hear from you regarding their pliers operability and pro’s/con’s against each other.
So far Im more looking at the Rebar+Micra combo, hard to resist, however I dont want to buy Rebar just to realise that its pliers arent physically big enough to grab some stuck bolt/screw once in a while, heck, even if its only once but situation requires it, it would suck to realise that at that moment, in that situation my fancy tool is worthless!
ST300 on the other hand is a monster of a tool, but neither Rebar nor ST300 will be used as my city EDC setup, so weight isnt much of an issue.
I looked at Ganzo G301B for short moment, but I realise that it neither comes with real warranty nor its pliers are going to stand up to abuse I might throw them into+no replaceable wire cutters which I find huge bonus.
Alright, forget about G301B, tell me about Rebar VS ST300 :D!
