Help me stiffen up FW1A Pro e-switch button
I love this little light, aside from the switch. Every time I put it in my pocket, I turn it on.
Yesterday I had it in a man purse/flashlight bag, and opened it before leaving work and the light was on about 50%! I don’t know for how long, but it was hot. I put the battery on the charger when I got home and it was around 3.6v.
I’d like to make the switch harder to actuate. I’ve read of people using orings etc under e-switches to stiffen them up.
I’ve read that the tailcaps on these are glued on. I was able to take mine off with a fresh set of nitrile gloves and a bit of strength, so no issue there.
ETA: It has a metal button.
I didn’t see an obvious retaining ring in the tailcap for the switch. There was a very thin black thing, that I am assuming is a low profile retaining ring? It has 2 notches, on opposing sides.
I prodded it a little with a pokey tool, but didn’t want to mess it up, so I put it back together and figured I’d ask here before destroying it.
Any advice on how to get the switch out so I can get it stiffened up?
Tool recommendations?
Is an oring the best option?
Any specific size recommendations?
TIA
Yes, don’t forget to remove the nub.
I use either.
8.5OD 2mm thick
Or
9OD 1.5mm thick
Some FWs need the 2mm thick and some need the 1.5mm thick.
Awesome. Thanks.
Any advice on removing the retaining ring? It looks pretty svelte and I am worried I may thrash it if I use the wrong tool.
Yes, that’s the retaining ring
I used lock ring pliers before I had Lumintop’s retaining ring tool:
Oh that’s awesome. Thanks. I’m never hesitant to buy a new tool.
I do have several different types of lock ring pliers, and I will gently give it a shot. Either way, I’m buying that tool right now.
ETA: Looks like it is OOS, but nealsgadgets has it. Looks like I need to build up a small cart :slight_smile:
I don’t know for sure if the FW1A Pro is very different from the FW3A, but I had the same problem and evaded it according to this LINK.
I left the switch itself alone and made sure it can’t be pressed by accident.
I like to use my digital calipers. The pointed ends of the side used for inside measurements.
Good idea. I have an old set of calipers I can try.
They were under $3 on Neals…so i bought 2…and a flashlight…:slight_smile:
So, the retaining ring was looser than I expected. I was easily able to loosen it using the back of my calipers.
I went through some old orings and found an 8.5x2mm silicone oring. Score!
I had my cutters ready to snip the nub, but it just came off. I didn’t realize it was a separate plastic nub. Handy.
Got it all put back together.
Double check everything functions, including turbo. All checks out.
Button feels perfect now.
I’m glad I asked before hamming something up.
Thanks for all your help guys.
