Hi, I need help on this torch as in this link Review: TrustFire R5-A3 XP-G R5 1xAA 3-mode i need to find some batteries that last longer than 5min than my current batteries which are “UltraFire AX 14500 1200mAh 3.7v Li-ion” or a replacement torch same size…
THose batteries you have are about the worst. Try these instead: TF Flames
How much longer will they last roughly ? and does it matter that the ones in the link are 900mAh compared to my current 1200mAh ? sorry if this is a daft question i know nothing about batteries lol :~
Those are nice batteries and would last alot longer then 5 minutes.
TF Flames are what I use in my R5-A3. They are fine.
Definitely go with the Trustfires; I have a pair of these and they will work much better for you. I use them in my C3 and SK68 with no issues...
$6.12/pair from Manafont who is known to sell genuine Trustfire cells, not counterfeits!
I just noticed they are cheaper from DX, and the reviews are good there; I assume you wouldn't be gettings fakes from there either...
Can anyone recommend a better torch the same size and rechargeable and if possible more powerful light ?
And thanks i bought six batteries from DX website
Welcome to BLF! You'll love being here! :)
Buy a UF2100 and be happy.
If thats this one i think it might be too big to have in the pocket at all times compared to the FireTrust R5-A3
http://www.ebay.co.uk/itm/Ultrafire-UF-2100-XM-L-T6-1000-lumens-5-modeS-tactical-Flashlight-Torch-/251165622781?\_trksid=p2045573.m2042&\_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D2697069346559477433%26pid%3D100033%26prg%3D1011%26rk%3D2%26sd%3D221077399600%26#ht_2218wt_1220
Read this and then contact him and you might be able to get one
Link
*the*:Buy a UF2100 and be happy.
It’s only 2cm longer and about the same diameter than R5-A3.
BUT it uses 18650 cell, which has about 3x the power of good 14500 (which is about 15x the bad 14500 you have)
vxlomegav6:
Acording to eBay listing its 15cm long and my current one is about 7 - 8 cm long…
The R5-A3 is almost 10cm. See here.
UF2100 is about 12cm, R5-A3 is 10cm. Diameter differs about 2mm.
Just buy it, preferably from E1320 (= with better driver).
In the meanwhile you could also buy a good 14500, which should give you about half an hour runtime with R5-A3 on high.
