I need a fairly powerful
UV Flashlight with little or no visible light to demonstrate some UV Glow Powders and Dyes.
A flood to Zoom single 18650 at 3 to 5 watts sounds perfect but-
Will it be mostly invisible or also have stray frequencies in visible band ? Will I need a filter or are some 3 to 5 watters mostly pure UV invisible light (preferred).
Power should be enough to demonstrate in a dim but partially lit area ( dim Nightclub etc.)
Any ideas about a true 365nm model that will work well for this purpose ?
I don’t know of any decent zoomie UV lights. They could be out there, but I kinda doubt it.
Two suggestions:
1. Jaxman U1. Good UV light with a bandpass filter to block the stray visible light that comes out of most UV emitters. Its got good output, too.
2. Convoy S2+ UV. Very good UV light that uses a Nichia UV emitter which has less white light leakage to start with. More overall UV output than the Jaxman, but does have just a bit of white light in there, too.
I own both of these lights, so if you have questions I’m happy to help.
I bought the semileds (?) 365nm UV led from led4power, and the filter to block out visible light and it works great, really strong UV. Apart from that I would suggest convoy s3 host and cca 700mA driver
