So, BLFers, I have some ideas to mode these flashlights. The Blitzwolf is now a host only that I don’t want to be laying around incomplete, while the Amutorch is a fully functional flashlight that I want to improve in some way.
What I need from you folks are some hints and clues about things I can/should or can’t/shouldn’t do in these 2 lights.
Mod 1 – Blitwolf BW-ET1
Plan: turn it into a triple or quad (I need to check the space for MCPCB and lens)
Leds: probably Luxeon V 4000K
Batteries: 1 or 2 x 14500s
Major doubt/issue: driver modification/ implementation
Here is the stock driver. It was fitting into the head with lots of white silicone or potting whatever. I took it out and it got damaged in some components, so I wont be using it again.
My idea was to leave only the roundish part, taking out the 2 layers that are there, and then do something like a “piggyback” (never did one and I’m not sure if I can do one :person_facepalming: ) using a 15mm driver with Narsil from Lexel. The new “piggybacked driver” would be inside the head in some way, with 2 wires for the switch and 2 wires for the MCPCB.
QUESTIONS:
Is this idea doable/viable?
How hard would it be to implement my idealized driver configuration? (specially knowing that I never did such thing?)
Which would be the biggest challenges?
Mod 2 – Amutorch VG1
Plan 1: turn it into a quad
Plan 2: turn it into a thrower (making profit of the nice reflector it has)
Leds: probably Luxeon V2 5000K or some XPL-HI or Osram White flat (not sure which)
Major doubts/issues:
Plan 1 or 2: driver modification/ implementation
Plan 1: getting a proper pill/spacer
So, my biggest concern in any of the Plans is how to implement the driver. This light has no retaining ring (unlike the Thorfire VG10) and uses a 23mm driver (not 22mm, not 24mm: 23mm with a brass ring glued on it) .
Right now I think I see 2 possibilities: a) stripping the original driver and attach (“piggyback”) a L4P driver (for the Osram) or a Bistro from Lexel (for the Luxeon V2 /XPL-HI); or b) using the brass rings on the photo, trying to “fix” the driver (solder, glue, other, whatever…) into a ring, in some way and make it work…
(as shown above as example)
In any case, I don’t know how viable/doable it is, so I may need some hints both for a) and b) .
For the pill/spacer, this is what I will probably need, and will ask kiriba-ru if he has something alike in stock:
Also, an honest opinion from you people:
- Is this a better light for a quad or for a thrower?
- Does it handle the heat well?
- Is it worth to try making it a thrower due to the SMO reflector it has?!
Thanks in advance and sorry for so many questions and long post !
