I have Convoy C8+ XPL-HI which I want to mod and try osram white flat led. I am confused about needed parts, so maybe someone who had done this can check my parts list:
Convoy 5A driver - 2.08€ 69% OFF|17mm Fahrer für SST40 ,4 modi 0.1% 3% 30% 100%, max strom ausgang 5000mA, Temperatur schutz management innen|Taschenlampen| - AliExpress
or led4power - https://led4power.com/product/ld-a4-2-12amp-17mm-constant-current-led-flashlight-driver/
Led4power driver is nice, but probably overkill for thrower setup which will be used on max amps only?
Osram white flat from Led4power - led4power
or from intl-outdoor - https://intl-outdoor.com/catalog/product/view/id/73/s/osram-cslnm1-tg/category/48/
Is there any difference in led4power and intl-outdoor supplied white flat leds and led boards?
I have C8+ stock reflector with 7mm hole, so I am confused about which gaskets do I need:
7mm XP gasket from convoy and mod it with knife? - 2.27€ |Dichtung für XP led und 7mm reflektor loch|led showerhead|led ceiling light fittingled garage - AliExpress
Or buy 9mm reflector from convoy and 3030 gasket instead?
Thanks for help.
