Hi all,
I'm going to buy a c8 and need help for choosing the emitter.
I'd like to get some luminous intensity numbers for the following leds that seems common for this host.
Thank you I added the @5A column to the table.
I’m wondering if it’s possible to estimate other amperage’s values for the same led, to fill a row having just 1 measurement of lumen and candelas
Quite easily using test results provided by other members of this forum. For example, here is an SST-40 test which provides a graph showing output vs current (early on in first post):
Also i see you have ‘half current’ by the XHP50.2. Not sure what this means but the results look normal for the 3V version.
Also, it’s worth noting that whilst the CSL*M1/CUL*M1, SST-40, SFT40, and 3V XHP50.2 come in limited flavours with little difference between them the XP-L Hi, XM-L and SST-20 have different variants that have very different outputs. Especially the SST-20, as an example the 2700K is very different to the 6500K version so in these cases it’s worth clarifying which version you’re referring to. (After all, you don’t want to pick the SST-20 based on the 6500K figures and then get a much lower output by choosing the 2700K version.)
(Also, all figures will only be estimates due to LED tolerances, versions, differences in measuring equipment, driver and battery characterstics etc etc, but this is countered by the fact that the eye needs a fair amount of output difference to notice it. For example, unless doing a side by side comparison i doubt anyone will be able to see the difference between 800 and 900 lumens.)
I’ve already pulled the lumen values from the measurements threads, I’m asking if there’s a simple formula to calculate the candelas given the known c8 host and amperage/lumens.
Added to the table, thanks!
The measurements I found are relative to a 6v emitter so I reported half current values.
I’ve seen almost all throwers use 5000k to 6500k leds, but if someone can provide numbers for lower color temperatures it’s ok.
I’d just like to have an overview of macro differences in performance between these emitters so I don’t care about exact values. As you said it’s hard to tell the difference between 800 and 900 lumens without a measurement system or a reference.
Candela directly correlates to lumens. If the highest mode is 1000lm & 100kcd, then the same light making 250lm on a lower mode will make 25kcd. If you have the lumen output test chart and at least one candela measurement, you can calculate candela at all other levels.
