Can someone point me in the right direction to mod one of my L6's with a short tube? I want to get the same power as the original two batteries by just using one battery with the short tube. I guess I need some sort of boost driver and a short tube and that's it? Want to make the mod as simple as can be if possible. Would also be nice if the driver firmware had a battery check in it like the Q8 too.
or 2x26350 and short tube from L2?
Was hoping for 1 x 26650 (protected) as I'm am making it as a gift for someone.
Yes that’s all. The problem is that it’s hard to find a micro switch controlled driver. There is one 32mm on the KD, but for L6 is needed 30mm. You could try to sand it.
Thanks, it's a good back up if I can't find a 30mm. Nobody makes a 30mm to work for the L6?
Forgot about Lexel, thanks!
Lexel said he doesn't have a boost driver for the short tube. Whats the point of offering a short tube for the L6 if there is no driver available to run just one 26650?
Hmm. It looks like Lexel is still working on the boost drivers
Glad I didn't order the short tube then if nobody actually has a driver to work it.
