Hi guys
I have an Elektro Lumens ST90 Search & Rescue, 2200 lumens, 150,000 lux from 2012 so now 5 years on I am thinking of updating the ST-90 LED but what with ?
If anybody can help with a suggestions on what currant LED’s would work that would be a great help. The goal is max output run-time not important.
The light is Direct drive at approximately 9 amps with four 18650 batteries in parallel.
The original sale thread is Here
The ST90 AFAIK does not have a driver originally, just two switches, one with and one without current limiting resistor. You can leave it like that with the XHP70.2 but be careful to mount the led on a DTP-board and in very good contact with the body because it draws about twice the power of the stock SST-90.
Thanks for the help guys.
So you are saying I can just replace the LED with a XHP70.2 mounted on a DTP-board and I can still use 4x 18650 IMR batteries ?
Best place to buy the XHP70 from does anybody sell them already mounted on a DTP board ?
I am new to modding so sorry for my lack of knowledge.
Like I said I am a major Newbie at this so sorry for the dumb questions.
To wire 4x 18650 IMR into a 2S/2P that would be 7.4v right ? What is the best volts for the XHP70-2 ? I am a little confusted because the led is 6v on the website.
Leds are listed to have a certain voltage while in actual use the voltage varies with current. It is just not lineair like regular resistors or incandescent light bulbs (ok, those are not completely lineair either, but close).
Here’s the current to voltage (and output) relation of the XHP70.2 (graph borrowed from TLF-member Kof3):
The grey line is the voltage, you can see that when the current goes from 2-20A, the voltage goes from 5.7V to 7.3V
