I just came across these STADIUM LIGHTS . But I have not heard of any stadiums being retrofitted with them yet. Anyone know if they work as well as the common Metal Halide (whitish) or old fashioned high pressure Sodium (yellowish) floodlights?
High Power LED Flood Light For Football Stadium IP67 Waterproof 3 years Warranty 150-4000w led flood light
—-High power excellent quality with best price. Smallest size for highest power in the market.
—-High CRI up to 90-95.Light efficiency up to 130lm/w.
—–2-5 times bright than traditional light. 1/2-1/8 power to replace conventional lighting.
—–50-70% cost reduction compared to HP sodium or Mercury lamp.
—–30 times longer life-span than incandescent bulbs, life time 50000-80000hours.
—-High quality and most of companies difficult achieve a true 95% of high-efficiency lens.
—-Light directly designed to the outdoor. 120, 60, 40, 25 degree available.
—-Widely used in industrial, stadium, square, garden, gas station, warehouse, tunnel.
—-Environmentally Sustainable. No IR, UV or mercury. CE, RoHS Compliant.
—-Customized Color Temperature Available
—-Customized Wattage Support
—-Colors of Red Green Blue Amber Available
—-Delivery Time: 30 days at Payment
—-Price Term: EXW
—-Payment:T/T
—-According to the quantity ordered, discounts available.
Wow a 4000w Led would be intense… I get to play around with a lot of different lighting setups at work and currenty were replacing 1000w halide bulbs with 175w cree fixtures(use to be ruud before cree bought them out and decided to actually put their name to fixtures instead of just emmiters).
I’m really curious how they mount though as they don’t actually show the fixtures themselves. As well what are the dimensions of each fixture are.
I’d really like to order a couple 4k through work to play with but the fact there not CSA or UL listed makes it impossible.
claims that they already scored 2 successful cases in terms of stadium lighting :
- 100x70 meter Football Stadium in Malaysia. Less than half of the power was required for the same lux.
- 70x40 meter Tennis Stadium in Spain. Only 15.6 percent of the power was required for the same lux.
But NORIBACHI , a US-based LED lighting manufacturer, had also unveiled their new line of LED stadium lights in Feb 2103 : Their Floodlight.XXL is said to make use of proprietary technology, 378.HEX, to create directed light that is sufficient for both indoor and outdoor playing field and stadium applications. The lights are claimed to be much more directional, so producing less glare and light pollution than typical stadium lighting. Their hexagonal-shaped light boards boast of 378 diodes with a combined output of 66,000 lumens said to be equal to 1500-2000 watts of typical stadium lighting solutions like metal halide. They also said it was unfortunate that the Superdome did not have LED field lights, but to be fair these were not available when the stadium underwent most of the $336 million in renovations it has had since Hurricane Katrina in 2005. Instead, the building reconstruction team continued using the then-current standard lights on the field and most other locations throughout the building.
Beijing Olympic Basketball Stadium apparently has an LED display system, while the city’s award-winning Watercube uses coloured LEDs.
Cowboys Stadium in Dallas is the largest domed stadium in the world and the biggest NFL venue ever built, with a maximum capacity of 110,000 with an LED cove lighting system.
Cape Town Stadium hosted the game btw England and Algeria in the 2010 World Cup. The stadium’s lighting is known as Green Point with 432 LED luminaries tracing a wave-like pattern around the ground.
Where in the world can we get a 95cri LED with 130lm/W efficiency? Most (all?) of the LEDs that I’ve seen in that efficiency range are 5000-6000k with cri around 70.
I just came across these LED PORT LIGHT. But I was wondering whether these so called great lights can be good enough. Anyone know if they work as well as the common Metal Halide or high pressure Sodium floodlights?
LED LIGHT 1,000W IP68 ANTI-CORROSION –35° TO +65° FOR PORT LIGHTING
FEATURES:
—-High power(100w-2000w) excellent quality with best price.
—-Light efficiency up to 140lm/w.
—–2-5 times bright than conventional light. 1/2 power to replace conventional lamp,
—–50% cost reduction compared with HPS or MH.
—–5 times longer life-span than incandescent bulbs, life time 80000 hours.
—-High quality and a true 90% of high-efficiency lens.
—-Light designed for outdoor only.
—-Widely used in industrial, stadimum, square, garden, gas station, warehouse, factory.
—-Customized Color Temerature Available.
—-Customized Wattage Support.
—-Colors of Red Green Blue Available.
—-According to the quantity order,discounts available.
1:Consider about the structure ,weight,and heat sink.The highest for led lighting is around 500W.If more, the height will be a bit high for installation.
2:Now, we use 145lm/w led chip light efficacy.THe lamp efficacy can reach 110lm/w.
3:To the life time, better you can choose product which pass the FM-79/FM-80.
need 60000 lumen or more to brighten in four course of it
in totality 240000 lumen enough to brighten that if less than it be
this affect to player in to their game and affect judges to in order that they cant diagnosis what happen in the game and affect onlookers to not can see the game properly
this issue with the distance of the any one to lawn
even cameramen cant record properly
if you use led try to attend this that led in huge sizes can consume energy as like as mercury hid bulb but advantage the led technology in time lapse may solve this problem
if it was like thing you told lighting official of stadium do it certainly
20 of Dale's cannot brighten more than 30 meter
in just you stare 240000 lumen you become blind , human eye cant tolerance more than 60000 lumen just sun in hot summer sky in equator produce 80000 lumen in 1 m2 square in earth that no body can stare directly into sun fore some seconds this damage eyes permanently
if 240000 lumen is not enough to brighten football stadium?
look at 240000 lumen how much LED you must power on to give this issue
hamedshh, I think you may have missed the fact that djozz was making a joke. Maybe it didn’t translate well. Anyway, if you used the brightest light Dale has made so far, it would take merely 12 of them to reach 240000 lumens! However, I think he only had it that bright for a short time.
Dale is a member here. His screen name is DBCstm. He comes up with some outrageous flashlights sometimes! For instance, he owns a 3” long flashlight that he calls the Texas Poker. It is capable of around 1000 lumens from a single 10440 cell! He has made flashlights that you could carry in your pocket that are capable of producing over 5000 lumens. The flashlight I mentioned above that does 20,000 lumens is a BTU Shocker that he modified and put 3X XHP-70 in it. He said it only made 20,000 lumens briefly. Another member, Old-Lumens is building a new handmade light that will produce over 20,000 lumens when it is finished. It uses a single Cree CXA3590 emitter and 9X 18650 cells! He has already tested the emitter at 45 volts and 4.25 amps! Here is the link to that one.
