It tells me that your cells are very worn out or more likely that you have high contact resistance caused by the poorly designed slider mechanism used on most chargers, that give wildly inaccurate IR readings.
Take 10 readings, resetting the slider each time and take the lowest number as your approximate IR number.
It’s like you have resitance in series with the cell, so if you draw 1A on a 250mΩ cell you will get a 250mV drop (roughly as the internal resistance varies with the state of charge, temperature and current).
You’ll waste more power in the cell, and with the voltage drop you wont be able to draw much current.
High power cells have a very low internal resistance.
Reduces Voltage under load, limits the current the cell can deliver, causes the cell to heat up more during charging and discharging. Generally makes the cell unsuitable for high current applications. Could also be a sign of an internal short in extreme cases that may cause self discharge.
Think of current as water through a pipe. As the diameter of the pipe gets smaller. the resistance goes up, thus, less current flow with high(er) demand.
Most of the higher amp cells will test lower in resistance (Sony VTC 5A test very low)— you can get a baseline avg for cell types/brands—as they get worn out that number will rise—— the sanyo red (laptop pulls ) usually test real high over a 100
Those cells testing really high —check them on the tail end of charging —if they take forever to finish charging or get very hot when charging above 4.10 v
Toss them —they aren’t worth keeping —- their capacity is probably low also
