Hey guys just hit the jack pot I pick about 30 of these from a company that does testing on them then tosses them for recycling. Also ? on what is the amp hrs on this battery Sanyo UR18650SA P44a
NICE!!! You lucky dog, you!
Name:Sanyo 18650 UR18650SA 1300mAh (high Power cell) ba Number:UR18650SA Specifications:3.7V 1300mAh |
Product Info
Item
Specification
Nominal Capacity
1300mAh (0.2C, 2.75V discharge)
Minimum Capacity
1200mAh(0.2C, 2.75V discharge)
Charging Voltage
4.2 ±0.05 V
Nominal Voltage
3.7V
Charging Method
CC-CV (constant voltage with limited current)
Charging Current
Standard charge: 650mA
Rapid charge : 1300mA
Charging Time
Standard charge : 3hours
Rapid charge : 2.5hours
Max. Charge Current
1300mA(ambient temperature25℃)
Max. Discharge Current
15A(ambient temperature 25℃)
Discharge Cut-off Voltage
2.5V
Cell Weight
48.0g max
Cell Dimension
Height : 65.00mm max
Diameter : 18.25mm max
Operating Temperature
Charge : 0 to 45℃
Discharge: -20 to
60℃
Very nice.
Those particular batteries I believe are 1300mAh
ninja edit JohnnyMac beat me to it ![]()
Yeah, but they can handle up to 20 amps. ;) Never mind...
scaru, those are SA, not SAX. They might handle it, but they are not rated for it. :P
P.S: Picture size 100% would be great..^^
I have cells and while they may only be 1300mah they are solid performers. I would take them over an Ultrafire or other cheap 18650.
do you mean to tell me you got ~300 of those for FREE?!
I think I’d build a lantern w/ 1s100p lol
Have fun charging them for the next month ![]()
Awesome score! If you don’t build your ~100 million lumen light array, maybe drop me a PM about 6 or so of these?
I’m pretty sure that these are the “high demand” Sanyos, like the Sonys I recovered and others that are used in tool packs. If they are, you will notice no difference between these and say a normal 2600 mah cell. In fact, you might find your light is actually a little brighter for the first 10 minutes or so. At least the high-demand 1500 mah Sonys I have are like that. They are GREAT batteries in their own right.
Seeing that they were only 1500, I almost chucked ’em. Glad that I didn’t. They rock. They may not last quite as long as a 2600, but they have PLENTY of power. Only downside I have seen with the Sonys is that when they run outta ooomph, they die very quickly. In other words, they maintain the highest output possible for as long as possible, but when they peter out, they just die, really quickly, almost like a ni-cad. The Sonys do anyway. YMMV with the Sanyos however.
I could be interested in a few too.
interesting, and good get!
How many seconds for each battery? ![]()
@GottaZoom: About 5minutes. :D
Better than I cam up with - I figured on < 4 unless regulation were to increase draw to maintain brightness as the volts drop (of course heat fade could change that, too).
