Just got 2 Sanyo UR18650ZT 2800mah protected in the mail today. Both around 3.7 volts on arrival, charged them at 1 amp in an Xtar SP2. Charged about 2 1/2 to 3 hours and the light was green on both, one was fine at 4.18 volts, the other was very hot and at 4.04 volts. Is the battery bad?
Get it outside. Do not keep it in your house. It’s bad and dangerous.
Figured it was bad, didn’t know if maybe the protection circuit needed resetting or something. Did put it back on the charger for about 40 minutes and the voltage went to 4.09. I myself have never had a battery get that hot, not even the cheap baby blue Ultrafires. I could hold it in my hand with no pressure but could not hold it applying pressure. It’s now off the charger and soon to be outside.
Yeah, as PilotPTK had said, it’s pretty bad.
I reckon if there wasn’t anything wrong the battery, the heat would have damaged it by now… li-ions hate the heat.
Did you buy those from Fasttech or were you just using that link as reference to the type of battery? NEW Sanyo (along with LG, Panasonic and A123) batteries DO NOT fail on first charge. They just don’t….
PPtk
Yes, they came from Fastech, got them Friday, charged them for the first time late Friday night.
First thing I’d do: Charge two known good batteries in the xtar to verify it’s charging correctly. Second thing I’d do if the charger proves to be ok: Have a very frank and far less than polite conversation with the vendor who sold me the “new” batteries….
To reiterate and reinforce what I said, You are about as likely to win a multi-hundred-million dollar lottery prize as you are to witness a catastrophic (overheating counts, ask boeing) failure of a Panasonic/LG/Sanyo LiIon battery on the very first charge cycle. It’s just so close to impossible that it’s not even worth calculating the odds…
If your charger proves to be good and you bought “New” batteries then flat out, plain and simple, no doubts about it… Your vendor lied and you didn’t buy “New” batteries…
Sorry if i sound pissed off, but truthfully, I am… LiIon batteries are VERY safe as long as they are treated with respect. When vendors make it impossible for a customer to do that because they have already compromised the integrity of the cells and sold them under false pretenses, they harm the whole industry and endanger lives. That’s worth being pissed off about.
PPtk
The charger is only about 6 weeks old and has been used to charge Kumabear Panasonic protected 18650 3100mah and 3400mah, Trustfire flame protected 18650 2400mah, baby blue Ultrafires, laptop pulls(LG and Sony), all successfully. Unless the charger just broke, it’s the battery. Just put 2 Kumabear Panasonic 3100’s on the charger to retest.
Concerning this;
How do you know this as fact?
What makes it so close to impossible?
That’s almost like saying “BMW’s Never break down. They do, and they have mechanics that make a living fixing them and Lexus, Mercedes, etc.
Any manufacturer can have a bad batch or bad parts.
Not trying to be a D*ck, I am just not getting how this can be so absolute about the batteries not being able to be bad out of the box new. Is it something to do with the chemistry for these better brands?
I like Panasonic batteries and hope I never get a bad one, but It wouldn’t surprise me if they have some sort of failure rate.
Concerning the Boeing thing, I do not think that battery was an old one that was returned or found in an old laptop:) But maybe from a Prius:)
Thanks,
Keith
That cell acts like several of my bad cells from laptop pulls. I just had one do this EXACT same thing. I mean to the letter and the same volts. Same heat etc. I wrote “bad” on it in permanent marker and moved it away from my other cells.
It has cooled down and I think it is safe just sitting there but not to use or try and charge.
Just an educated guess but I think you got an old battery from a laptop or other device that was repackaged.
Fastech needs to start investigating this.
Did yours also show 3.7V initially?
I think lots of people are on the Fasttech bandwagon but they may not be all that different than many other vendors besides the quick shipping times. We have seen Trustfire battery wrappers, fake knives listed as the real thing, and now this.
Guys, let's take a chill pill and not start hating Fasttech. There is no proof that they have done anything wrong, it i all speculations so let's not waste our time speculating.
His point is not that they never fail, but that they never fail on the first charge. Using your analogy he is saying a BMW never fails on the test drive.
Couldn’t it be something simple like maybe it was dropped pretty hard at one point in its life?
There’s other reasons for failure. I also look at it like this… The sanyo only got hot. What would a cheap battery have done?
Couldn’t it be something simple like maybe it was dropped pretty hard at one point in its life? There’s other reasons for failure. I also look at it like this… The sanyo only got hot. What would a cheap battery have done?
Yeah, that is my personal guess: the internal separator is broken from being dropped/rough handling.
Just removed 2 Kumabear Panasonic 3100mah protected off the charger, both at 4.19 volts and not even warm, the charger is still working properly. As for cheap batteries, I have at least 20 of the cheapest of the cheap, the baby blue Ultrafires and none of them has ever even gotten warm. By the way, I never bought any of the Ultrafires, they all came free with UF-139 chargers. Could be damage from transit or maybe a bad protection board. Could very well be Fasttech has done no wrong.
The battery may have been damaged as can happen with any product. Just tell FastTech the problem, and that you had to dispose of it, and I’m sure they will replace it with no questions asked.
Remove protection board and charge ti again.
No, no, no, and did I say NO that is a horrible idea. The problem is most likely inside the cell, and charging it again could cause a vent with flames incident.
Please listen to the man in the diaper.
