Generally speaking, cylindrical battery chargers on the market can charge LiFePO₄ batteries
Most chargers are compatible with Li ion 4.2V and Ni MH 1.5V batteries
However, chargers generally cannot immediately recognize Li ion 4.2V, Li ion 4.35v and LiFePO₄ 3.6V batteries
Therefore, the battery type should be carefully selected when charging
Suppose the charger is charging the 26650 LiFePO₄ battery and suddenly loses power for various reasons, such as power failure, poor contact, or child touch. Then it is powered again. What will the chargers on the market do with this battery? Maybe some chargers will automatically charge to 4.20V?
I am not sure about this for all chargers that support, but a well designed charger should remember the conditions of the last manually selected charging parameter.
As you guessed, many chargers on the market probably don’t do this.
Thank you very much for your information, but I need to confirm with you that charging the IFR battery must be manually selected. If it is not selected, it is charged to 4.20V by default
Now the power is cut off and the power supply is restored. Will charger continue to follow the previous procedure?
Ok I just verified my MIBoxer C4 smart charger stays with the manual Battery Type setting after a power outage —- I manually set the charger to LifePo4 for 2 cells, then I picked a charge rate of .20 amp —— I unplugged the charger for a few minutes and plugged it back in — the mode stayed at LifePo4, but the charge rate went back to Auto or full output of 1.5 amp
Charging current rate could be troublesome. Not long ago I decided to do some discharge tests on a few PKCell branded AAA 850mA Ni-MH cells. In a hurry, I started charging them at 1A in my Lii-500, and It ended up being a bad decision. For some reason, my Lii-500's slot 2 completely missed cell charging termination, and when I checked the charger a few hours later I noticed the disaster: the cell in slot 2 (number 4) was extremely hot, its wrapper was completely deformed and there were some “glue” remains from the cell in the slot's positive contact. I ended up properly testing the cells in my PC connected EBD-M05 constant current tester with 4-wire battery holder. The result ended up being as expected: all cells but the number 4 one performed admirably; number 4 cell showed noticeably reduced capacity, and a lot higher internal resistance. So, I dumped it into our local battery recycling containers. I also decided to never use again the slot number 2 in my old Lii-500.
