how hard to push xp-l hi
looking to put an xp-l hi in an L2 and wondering how hard I should push it……not sure if Im gonna use a direct drive or linear driver…. thoughts?
Direct drive will be just fine as long as you have it on a DTP board. That’s all I use though, the only lights I have that do not have a dd driver in them are stock lights that I can’t open up to replace the driver and led.
What matters is how many amps you’re pushing, I ran 6.6A through a XPL HI on noctigon with a taskled driver and it killed it instantly. Since then I only run them direct drive, they don’t get past 6A and even in small hosts like the S2+ it works fine.
It’s like the old mechanic’s rule of torque: Tighten it till it strips, then next time go 1/2 turn less.
So drive it till it smokes, then next time 500mA less will do the job better
Just joking of course, but what’s life without a bit of humor!
Phil
DTP board? Direct to pill?
a.k.a. Direct thermal path…
whoops, ok cool thanks
The part I have italicized/stricken is a bit misleading with the context that follows it.
  • Yes, DD is usually safe w/ the LED on a DTP MCPCB.
  • Yes, the bond wires on these LEDs will poof easily once a high enough current goes through them.
  • DD current is not directly comparable to the current from the TaskLED driver, see below.
The TaskLED driver would either be buck or boost. The output from a typical buck or boost LED driver has peaks higher than the average current. These peaks last long enough to poof those bond wires, so the maximum survivable current from a driver of this type will be lower than the maximum survivable DD current.
Let’s reference RMM from RMM’s MTN-MAXlp thread:
the most powerful driver I have used was a linear with 14 x .350 7135 chips and tail spring mod. so around 4.9-ish amps
What AWG are you running to the led to get 6A and what cell? On the S2+ I’m assuming you’re using a single 18650. With a 30Q I can’t even get 5A, so I’m trying to figure out where my bottleneck is. Thanks.
What taskled driver ?
