How is your day , mine is crap so far
Does this help at all?
I'll give em a try, thanks guys.
If you have a 12v + ish power supply and want multiple XM-L emitters, would it be possible to run x number of XHP50’s (in the 12v flavor) ?
Heck maybe heat sink the hell out of them and run them direct drive?!!
Then again I usually have no idea what I am talking about :slight_smile:
Check my math
12v at 5 amps = 60 watts is equal to
6v at 10 amps = 60 watts or
3v at 20 amps = 60 watts
Sheesh no wonder things are frying (Or maybe I skipped somthing)
Have a read through this thread. There are several proven options. Unfortunately, some of the links may be outdated by now.
This one was used by quite a few members, & is easily tweaked by changing the resistors.
Hmmmm... makes me doubt my chances...
I've got a STL-V2 clone type light with one of the FT 3A drivers linked above. I've been waiting for Richard to get the U4-1A bin XM-L2s in stock so I could dedome, mount on a Copper DTP board, and combine with the 5A driver to driver this thrower a bit harder. Now you make me think this might be a waste of a good emitter.
Everybody who has used these drivers said they worked fine with thermal cubes. Which is why I tried them. The cubes seemed like a weak solution to a good mix of potting compound. I learned on the first 5 amp driver. I ran it for 1 minute 2 times back to back. That let the magic smoke out. Then I bought a 3 amp version from FT, that one ran slightly cooler but I wanted to make sure it was heatsinked very well before lighting it up for anything more than 10 seconds.. So, I potted it very well in an established potting compound and within 2 days a lightweight use it let the magic smoke out. I should also mention that before these 2 drivers failed they took out(killed) emitters first. So now I'm using a different driver all together.
Was not using the dropper for the initial build, I was using the first three LiPo cells I had to hand. They were not even fully charged, seem to remember 11.6 volts
But either way, a device for three cells should be good for 12.6 at least, and I;d say it should be a bit more too, …running any device that close to it maximum rating would not be good.
15 volts is what I read for that driver.
I hope you have a better day tomorrow. :slight_smile:
I would give you a big ole hug, but ……well ya know…:wink:
Thats all I came here to say. Oh…and WE LOVE YOU!
Are you saying you measured 15v or you thought it could handle 15v? Mountain Electronics lists it as a 5.5-12v driver. I’m fairly confident 15v could kill it being as touchy as it is.
15v
Its the same driver only Rich or someone else added some R020 resistors to make it 5amps....
I suspect he(Rich) does the mod though as I have not seen this driver offered anywhere else at 5 amps.
I'm really happy to hear that these drivers are actually working for people. I've tried 2, the 5 amp and the 3 amp, heatsinked well and they both crapped out of me.
I had a couple crap out before I started using thermal cubes. They’ve worked fine since then.
How are you using yours? Or, what did you install it in?
All in Uniquefire 1405’s so far. Most with aluminum pills, one with brass. I guess I should mention that I also put a thick blob of thermal paste between the contact board and main board, maybe that’s what you’re missing?
I’ll turn on the brass build for 4-5 minutes straight and let you know if it dies. It’s unique in that it’s the first one I’ve done using thermal cubes instead of the thermal paste between the boards. Don’t know if that’s a good or bad thing though comparatively, I only did it because I had more space to fill on this one.
Could be a change to a lower quality component on the board? It was not just me who had one burn for no good reason. 2 actually. I can't trust them anymore. Some others have suggested some good replacements. Maybe I'll try one at some point.
This is the driver that used to be my favorite.
I replaced most of my 3 amp driver’s that were in STL-V2’s and STL-V6’s and a few other knock-off brand’s with decent heatsinking with this driver and not one XM-L2 U2 or U3 has survived this driver.
Some died immediately some died month’s later.
I to am in the boat of buying better light’s already put together correctly at the start my latest being the 2014 Edition Olight M3x Triton which amazing enough seem’s to way outshine any of my 5 amp flashlight’s I had and makes my two Maxtoch SN6X-2X limited Edition series look very bad to after seeing this saw a couple of closeout’s on Olight product’s for a steal like the SR51,Olight M21XS XM-L2 and Olight S10R rechargeable and Olight has quickly become that brand that perform’s amazing well at a price I can afford that I look to first
Sorry for getting off track I agree something under 5 amp’s is more appropriate for longterm usage of the XM-L2 I have a few of the XM-L2 U4 series on there way to me from oversea’s I’m going to try out and see how it goes problem is I ended up giving most of my 3 amp driver’s away and have mostly 5 amp driver’s laying around if anyone know’s if these U4 version’s handle power better it would be great new’s.
One good thing about having extra 5 amp driver’s laying around is experimenting with other emitter’s like the MT-G2’s that Hank over at IOS is selling at an amazing deal buy from this guy at no hesitation he run’s a standup business….have a few light’s with these emitter’s and higher amp driver’s two running direct drive and they are amazing.
I mostly replied to this post after reading a few post’s of other’s loosing their XM-L2’s at this amperage and this and other thing’s have made me decide to stick closer to manufacture spec’s and pre-built light’s from reputable companies.
Sorry for your losses fella’s I hope you find what work’s best for you.
