You can see the archived poll results on the Wayback Machine:
https://web.archive.org/web/20221220093741/https://budgetlightforum.com/t/-/72897
edit//POLL CLOSED FOR NOW
What’s your normal amount of sleep you guys/gals get per night
I’m asking this because I get about 4-5 hours sleep every night and feel and look like I need more
I’ve been like this since a kid and now I’m over 40
I tried taking melotin but it just made me horrible the day after , kinda the feeling the day after 10 pints of dizzy water
I don’t want to take any meds really but I want more sleep
I don’t want to waste the time of the doctor and tell him I need more sleep as it’s not a massive problem
Depends, When I worked essential services I was pretty much on-call even on days off with shift work that was between 12-16 hours it would be anywhere around 3-4 hours.
Also might want to disable poll for now since there was already an issue addressed before with a new poll replacing the current build competition thats being voted on.
For quite some time now, I can only sleep for less than 6 hours per night. Mostly, it’s around 4-5 hours only. There’s an infrasonic source at approx. 65-70Hz somewhere nearby the house that makes a horrible buzzing noise in a random frequency pattern. It can be heard anywhere around the place. There’s no way to find it nor can I take any countermeasures to wipe out the signal with other frequencies. I tried white noise or other sound patterns to keep my ears distracted but such a low frequency can even be heard through earplugs.
i made the poll for 2 days… or should i just delete the poll and people can comment?
Personally I would disable the poll for now and have people comment at least until the build competition voting is concluded.
I need 8 hours, but i do sacrifice hours because days are too short
I mostly sleep 14-18 hours a day thanks to having ME and i also feel and look like i need more. ![]()
Sleep is a very complicated thing with time spent asleep being only one factor, the fact that melatonin (which is what i assume you meant) just makes you feel worse without helping you sleep more indicates to me that you’re waking up for a reason other than a lack of melatonin, and having to overcome the extra sleepiness caused by the supplement is making you feel worse. There are other explanations of course ![]()
Have you tried napping for the extra sleep? You don’t need to get all 8 hours in one go, which in itself is a generic guide to how much sleep you need and may not actually apply to you.
There’s also the option that you’re getting enough sleep but lacking the ability to wake up properly.
Melatonin puts you under. Niacin keeps you under.
Normally, I go to sleep as soon as my head hits the pillow, sometimes before. I keep things dark, not even a digital clock shining at me. And quiet. Only if the cats make a ruckus do I wake up before my time. And regularity. Right after “Cannon”, or lately “Barnaby Jones”, teevee off, unconscious 30 sec after.
Dark, quiet, regular. Only way to get decent sleep.
Failing that, melatonin in the smallest dose that does the trick. Wanna save? Buy the max, and divvy up the pills in halves, quarters, or even less. For me, it starts kicking in at about the 20min mark. That’s when Mr Sandman pops over. Miss that, and forget it. Do not try to stay up even 5min to finish reading something or watch something, nothing. Force yourself to stay awake after the mood hits, and then even a second dose won’t work. You’ll just end up fuzzy-brained all the next day. After popping it, lie down and make like you’re going to sleep immediately. Ie, use it or lose it.
So, small dose, be ready to drop off immediately, then do it.
If you still wake up later on, or don’t get a restful sleep, load up on NicOH. 500mg is good. 1000mg gives a nice warm “niacin flush”.
Avoid too much for too long to not overstress your liver.
I go for straight NicOH, the good stuff, not the “time-release” stuff (niacinamide, etc.). You can try various forms, see what works best for you.
So yeah, melatonin to put you under, and NicOH to keep you under.
I am non-24.
https://en.wikipedia.org/wiki/Non-24-hour_sleep–wake_disorder
I sleep about 50% of the time.
If my day is about 24 hours long, and it frequently isn't, then I'm asleep 12 hours per night.
I take time release Melatonin and psych meds that help me sleep.
All good info here guys @lightbringer I’ll try that
7 hours for me is about perfect, 8 or longer and I feel sluggish all day. 6 and I’m a bit tired but less than 6 and I’m an asshole.
Kind of been touched on already, but sleep hygiene is very important. I don’t have caffeine after midday, else I’m screwed.
I try to go to bed and get up at the same time every day, I find that ‘awkward zone’ where it’s too late to start on something else and too early to go to bed is best spent reading (paper books- no screens!).
I hope you find something that works for you, good luck!
Sounds dreadful! There was a case of infrasound pollution a few years ago down the SW of the UK, accusations were mostly made against a mine in the area, it might be worth looking into whether there is any mining activities near you?
It’s the Lizard People expanding their underground bases again.
Between 7 and 8 for me (I prefer 8). If I get less I feel like I`v got Flu next day and if I get more I tend to have a headache. I don`t drink alcohol, smoke, take pills or even have cafeine, I read in bed half an hour before sleep using an Incan flashlight and go to sleep quite quickly.
My sleeping time is about 6-7 hours. I turn off my phone one hour before sleep. It helps a lot ![]()
Never been a morning person, but that will work if I get sleep early enough so does melatonin work like almost any time of the day? Pop a pill, get sleepy and fall a sleep no matter how long you slept last night?
Me? Unno, never tried it for anything like that.
Won’t kill ya dead or nuttin’, so you can always try it.
But it’s not a sleeping pill, it’s not like getting slipped a mickey or anything. You have to be ready for sleep, and it’ll come if it otherwise can’t. It’s kinda Zen…
I’m somewhere around 5h but using 10mg of Melatonin will knock me out within 10min. After i woke up (even after 4hours due to alarm/work) i’m totally refreshed, brand new person.
What i have found is that using EU (kids) dosage 1-3mg will only make you angry. American size pills are perfect.
If melatonin works for you, great! I’ve tried 2.5mg, 5mg, and 10mg melatonin… zero effect. (Maybe a slight headache with 10mg sometimes, though that might just be my imagination.)
Someone else I know, can take 5mg melatonin and be out within minutes.
I suppose it all depends what the underlying cause of insomnia is, and how your body reacts to melatonin.
Other things to try: OTC sleep drugs containing diphenhydramine, or just take Gravol (or generic), it’s the same thing and a lot cheaper. It seems to make most people drowsy. Hit & miss, IMO, but it’s worth a try. I find that if it works, it works well; if it doesn’t work, it makes the night awful.
After that, you pretty-much have to get a prescription for something stronger. There will be some prescription drugs that will work (it probably will not be the first one you try), but they come with more serious issues of dependency.
Non-drug approaches are various behavior-modification therapies. Most is common-sense, but for people without common-sense it can help a lot, and it has no down-side.
Stay away from psuedo-scientific nonsense, or “ancient Chinese” medicine. All those new-age things will do is take your money.
Finally, be aware that not everyone needs 8 hours of sleep. Some people can be perfectly fine with 6 hours or even less. If you wake up after 5 hours of sleep and feel wide awake, just get up and enjoy the extra 3 hours of free time that day!
I’ve struggled getting a good night sleep most of my life, and hate taking meds too. So I found a combo of things that all together, can get me a good night sleep quite often, which is a miracle.
I highly recommend trying them all for a week before you give up.
2) Low lighting after 6pm. I now have indirect LED strip in all rooms, but a good life-hack for you is to just shut off the light in the room you are in… and instead turn on the light in the room next door. The flood of light coming through the doorway is plenty once your eyes adjust. Also after 6pm, use the settings on your PC and phone to dim the backlight very low. I go to 8% brightness.
3) All the crap you have already been told, establish a schedule and stick to it, don’t drink caffeine after 6pm, blah blah.
4) An hour before bed, lower the thermostat 2 degrees F for the night. Being warm and cozy does help me fall asleep, but it’s not worth the poor sleep I get later. This trick works because your body can regulate it’s temperature without waking your mind. It simply increases or decreases blood flow to a cool arm or leg, instead of waking your mind half-way to deal with the covers. Typically I just leave one foot exposed to cool air.
5) 30 minutes before bed I take 2 Luna pills. They are almost identical to the cheaper Sleep aid from Walmart, but for some unfortunate reason, the expensive Luna works much better, and with only 6mg of Melatonin instead of 10.
6) Honey Nut Cheerios. I don’t know why, but it really helps me sleep.
7) Relaxation breathing. At this point I am in bed, but often can tell I am not melting into the mattress properly. So I breathe deep, then slowly let it out while focusing on a muscle group to relax. Then repeat with another muscle group.
8) Never go to bed owning Bitcoin.
