It’s been a dang long time since we looked up to and salivated at Maxabeam-type HID lights. Now that sooo many flat LEDs of super power are available, I wanted to ask: how do modern powerhouses perform against the once-untouchable Maxabeam?
I’m genuinely curious.
According to the specs…
"Every Maxa Beam Searchlight has the following range when set to high beam and focused to its tightest 1° spot:
- 0.25 lux @ 6,925 meters (4.3 miles) [ANSI/NEMA FL1 Standard Range]
- 1 lux @ 3,500 meters (2.15 miles)
- 12 lux @ 1,000 meters (.62 miles)
The measurement and calculation of Range is defined by the ANSI/NEMA FL1: Flashlight Basic Performance Standard. According to this standard, a flashlight’s range is the calculated distance at which it will provide a light intensity of 0.25 lux on target.
Using the calculations set forth in the ANSI/NEMA FL1 Standard, the Maxa Beam’s range is nearly 7 kilometers!"
Is this still a blow-us-out-of-the-water scenario? Or do modern measurements yield something different? To me, it looks like nothing we have can get near this.
