Originally, on the garrybunk’s DST thread, I was looking for a body to make a shorty DST, and the A8 was suggested.
So, I bought a very nice A8 from Ebay, and tried the body with the DST, and it worked, but then someone mentioned that there was an A8 clone, whose body would also work with the DST, so I bought 2 of those, one for the DST, and one spare. I did that because I liked the Trustfire A8 I got, esp. the anodization, which reminded me a lot of the ZL SC52.
So, I still had one spare A8 clone left when I was trying to make a short STL-V6. As mentioned earlier in this thread, I originally thought that I’d be able to make my STL-V6 a shorty using a C8 body, but the FandyFire STL-V6 I got from Wallbuys doesn’t have a separate ring between the head and the battery tube, so tried the body from my spare A8 clone, and found it worked, which is where I am at now.
I’ve since found some cheap 26650 lights with black bodies on Ebay, and am waiting for them to see if they’ll work with both the DST and the STL-V6.
Thanks for fixing my image, freakin imageshack made some changes…
This doesn’t come apart, that’s why I wrote 2x26650 tube. But I thaught this info could be useful for someone, sometime.
I ordered this in June, flash pilot linked it in the BLF deal thread, from time to time it gets discounted.
Does that dual 26650 tube work out well for the STL-V6? what I mean can the single LED handle it without burning out?
I ruined a Trustfire 3T6 by running 4 18650’s which I know was a dumb move by me but I couldn’t ever forgive myself if I did this to an STL-V6.
Any place to get that tube right now?, I can fine it anywhere? Thankyou for going through the trouble of posting the picture and for the info…that would be amazing to run this light with two 26650 batteries.
The voltage on a 26650 should be the same as 18650, just with much more capacity (amps). If you could get it to screw in properly to the STL-V6 (I don’t think you can), 2x26650s would be the same as 2x18650s, just with loads more capacity.
Of course you can use the bigger tube, the battery tube fits perfect and makes good contact. I have used it several times, I have measured lux on it just before ten minutes….A two 26650 light is a nice size.
I just have seen it on meritline and this was my only order from them. You could make another thread and ask if there are extension tubes for the trustfire A8 or similiar lights availabe( f13, f15…), maybe someone has a advice…
In stock form it didn’t made contact properly(with the stock tube too) but since I modded it to mtg2 and a different driver it works well with two protected soshines. I didn’t even had to make a spring like on the standard tube.
Here is the picture I tried to add last time to show the copper wire spring I added on the stock tube:
