I would think that the light would have reverse protection so glad to know that, the spring was in perfect condition, so I am stumped, but it really did a number on that driver, completely melted together and stunk bad, that was what got my attention was the smell, but I can assure you this won’t prevent me from getting a new one, looking for some codes right now and thinking of buying new 14500 cells since it very well could have been a cell just went bad as you mentioned and just vented beats me, the light is one of my favorites.
Yeah, from your above description I was thinking that your cell may have gone bad. It could have shorted as well and took time to heat up. Very strange situation.
*6 would have a lower high mode than *8. If you don’t plan on using 100% on *8, 100% on a *6 might suit you better, plus moonlight mode will be a bit dimmer. Since I don’t need a super low moonlight, I’d keep using the *8 and, if it’s a biscotti driver, set it to one of the group modes that goes up to 50% of max current for high, so you still can access the 100% one day, if you feel like it
thx.
Learning a lot from reading these forums.
Are Astrolux C8 and Convoy C8 the same thing? Looks like I should go with XP-L Hi version for a thrower?
How do these compare to Sorfirn C8T?
The design is pretty similar among them, and for throw you should definitely go with the XP-L HI
Convoy has a linear driver that maxes at 2.8 amp. The Astrolux and the Sofirn use FET drivers, so they can potentially be brighter (reaching from 4 to 6 amp I think), and the Sofirn has different knurling on the tube and different tail design
I ran the numbers from the stock-lights’ spex, and going from 6 to 8 is gaining only something like 10–12 more light at the expense of 33% more current.
Ie, you’re killing your runtime a bit and just generating more heat than light.
Hey, what did you end up buying so far? Just curious as I enjoyed this post and hearing everyone’s suggestions. Have you done your first group buy or flash sale yet?
