Big thanks to comfychair, JonnyC (you can also do the open command window here in Windows 8 ), WarHawk, Ima4Wheelr, Sixty545, Dr Jones, and Tido. A lot of knowledge and effort had been put into this.
Next step is to learn what the code means and how to manipulate it.
Just don’t do what I do…flash a firmware you “think you want” and then permanently (aka solder) down the driver, getting it back out to re-flash to another one is a pain in da butt! (ask me how I know )
And thru my getting my Certs and Cisco training, there are ALOT of keyboard shortcuts (yeah…I actually went thru the course when it was still a .com vs a .edu, cost me $25K!!!)
On a P60 I use a piece of flexible cord, 1/2 inch long. Solder one end to the rim around the driver seat (on the outside of the pill) and the other end to the driver edge ring. That way I can later simply lift up the driver and twist it more than 90degr. for attaching the clip for reprogramming and then twist it back again In place.
See if you can help me! I’ve been all afternoon with the theme of “How To Build a Flashlight With Perfect Modes”
I’ve been a long time trying to flash my convoy S2 driver and not exactly I am doing wrong, to reassemble no lights in any way (if along the negative pole of the battery with the upper contact of the LED lights themselves ). I followed the step by step AVR Drivers - Flashlight Wiki and have read many posts in the forum but can not get the driver to work.
The clip and the drivers I think I’ve done well, if I flash with this command(after putting in folder AVRdude all the files of the folder “Programmable”):
avrdude -p t13 -c usbasp -u -Uflash:w:BLF-VLD.hex:a -Ueeprom:w:BLF-VLD.eep:a -Ulfuse:w:0×75:m -Uhfuse:w:0xff:m
I get this:
but when I test the driver on the flashlight will not turn on!
The driver I use is this: https://www.fasttech.com/p/1186301 , but I have another problem …. I have also tried with the Convoy S2 (I think that is exactly the same) and although I have managed to flash it and try several times with other files. hex had the same problem because they did not light, now my is impossible for me to connect my convoy driver
The driver gives me error Convoy is the S2 but when I started testing and got flash it for the first time, it is well connected to the driver. After flashing several times it suddenly has stopped to connect to the driver. I have another Nanjg 105c (of FastTech) that looks exactly the same and that I get to connect, the picture I posted is recently when I managed to flash the file in the “Programmable” of http://tarnover.4gh.eu / BLF-VLD/BLF-VLD-0.4.zip vesion.
I connected several times the driver of the convoy S2 if I was wrong but I think it’s worth noting, seems to have died, is it possible? If he is dead … I have to go buying several Nanjg 105c to test if I break them. The 105c Nanjg I flashed, why not turn on the flashlight?
I’m buying these chips to try to replace them and see if I have better luck…. until they get me to do more tests I will try to learn how to program them
Use a flat/spade tip, heat all 4 legs on one side and use a pair of tweezers to GENTLY lever under the chip and lift that side off the pads then go to the other side.
Thanks for the tips! After some modifications and testing …… I’ve made a breakthrough!
1) Is the original configuration of the leads. (I think that was the problem because it was not able to correctly program the ATTINY13)
2) As it could be a connection problem, after cleaning the ATtiny13, I decided to solder the ends of the wires with some solder. (sorry for the quality of the pictures, not very well appreciated)
3) The next step was to try and desolder the ATTINY13 directly on clip. (I did not get any good results, got the same errors with the two previous ATTINY13)
4) After investigating many forum posts, find similar errors …. etc I find this post and after reviewing the positions of my cables, I made a change after change …. I did a couple of tests and AVRdude …. GOT IT!
I quickly put a few drops of tin in the driver to make contact with the pill, I now know that the flashlight was going to turn on!
Low mode! I put the .hex and .eep file of “programmable” folder, Now to see if I can understand how to program!
The next step for me is to learn to modify any firmware driver (I wanted to try luxdrv among others)
I have bought everything I need to reprogram my Nanjg105c.
I am planning to add a hall effect to the circuit, and connect the output of the hall to the Attiny’s ADC.
Do you have any idea how do I read the values of the ADC?
and another questions, is the possible to use the Attiny in order to “completely block” any current to the led?
I mean is that possible to reprogram the driver to be turned off while ADC on low, and turn on while ADC on high [for example].
