charging time(hours)=(capacity of battery mAh)*(1-charging efficiency)/current being used to charge the battery mAh
for example:
If charging a 2000mAh AA battery with a current of 1000mAh and an efficiency of 90%, the charging time would be
(2000mAh*(1-0.9))/1000mAh=200mAh/1000mAh=0.2 hours or 12 mintues
how about if I charging 2pcs/8pcs aa battery together? how long the time will takes?
how to know the current and efficiency?
For a 2000mah Eneloop it takes just over 120mins at 1000ma charge current, actually very efficient. And because it has 4 bays which each charge at 1000ma it will take the same time whether it is 1 or 4 AA being charged.
I understand as like this, of correct?
same 4pcs 1.2V aa ni-mh batteries, 2300mah.
and charger specification:
DC 1.2V 1000 mA
D/C/AA/AAA *1: 1000mA (850mA-1150mA@1.2V)
*2/*3/*4: 2000mA (1700mA-2300mA@1.2V)
charging current: 2000mah/4=500mah, 500mah current will charge 2300mah in 4.6 hours
ingnoring losses, 4pcs aa ni-mh battery will takes 4.6 hours to charge.
That site gave you a bad formula. The charging efficiency is the portion of the energy delivered by the charger that the battery retains, so it effectively reduces the charge rate. The formula should be:
. . . . T = C / (╖ * I)
or in long form:
. . . . Charge Time (hr) = (Battery Capacity (mAh)) / (Charge efficiency * Charge Current (mA))
For your example:
. . . . T = 2000mAh / (0.9 * 1000mA) = 2.22 hours
The efficiency is difficult to know since manufacturers don’t publish it, and it decreases as the cell ages and its internal resistance goes up. I’m not sure if it might vary depending how deeply discharged the battery is, too. 80-90% seems like a reasonable estimate, but do be aware the calculation will be approximate. This is fine if you just want an idea how long you are going to be waiting.
If you want to use this formula to decide when to terminate charging, it is not advised to do so for high charging currents. It should be ok to do so with NiMH batteries for low currents (below 0.25 C rate). The official test for NiMH cycle life (IEC 61951-2) actually moderately overcharges the batteries, but does so at a relatively low rate.
However, since your EBL 906 is a smart charger, which is good, it uses a method called -dv/dt termination to detect when the battery is full, instead of estimating it based on time or voltage. You should not need to decide yourself when to stop charging. Just remove the batteries once the charger indicates it is done.
