fitted a tailcap from the cheapy zoomie wurkkos sends you with their 18350s. took like 15mm off it. chopped off the cheapy tube threads and slipped them over the anker. perfect fit, crazy.
gonna be like 100mm. bit longer than ts11 but about same size as my sp33s shorty.
gonna mickey mouse a pill out of plumbing shit from home depot. that’s ez. the hard part is creating a lip with o ring groove for the glass, bezel. by hand.
I love the plumbing part. I have one of those projects right now, too.
I tried making an o-ring groove in a bezel with a hole saw and woodworkong drill press. It didn’t work very well. Despite holding it in a vise the best I could, there was too much vibration for the tolerances I was trying. I would probably have better luck using the hole saw by hand to slowly scrape out the material.
Thanks for the update and pics. Always fun to see what people are working on.
did it seal well? I’m gonna do it by hand. those hole saw bits are usually thick. hope i can find a 1mm thick one. if not i might just use a tiny flat head and scrape a groove.
need to wait for the ts10 before all that. $16 shipped from the wurkkos site right now. ordered a couple days ago
It’s still a work in progress and I haven’t had success with the o-ring yet. I bought two different designs of cheap hole saws to try. I forget where I left off with those and can’t look right now.
I thought about buying a cheap 1.5mm ball end mill and trying it in a rotary tool but I don’t think it would work well freehand or in a drill press. I could see it snapping pretty easily if there’s any chatter, which there would probably be a lot of.
chipping at this little by little. still need to go thinner but here’s where im at. new plan for o ring seal. ok. so check this out, let me know what you guys think.
i want to use 2 pieces of 1mm glass lens glued together. top plate glass will be a few mm smaller in diameter creating a small step. the top glass will be near flush with the top of the bezel. in that step will be the o ring sanwiched between the bezel lip and the glass step.
will glue dry clear? 2 pieces of glass plus tir lens too much? how well will this seal? I’m sure it’s been done before…
They typically use a UV cure. Of course the application and cure is key. Then, of course, there is the part (glass) sizing and mechanical assembly. Maybe doable ?? Interesting idea. If you have the tools, maybe a 2mm thick glass and cut/grind the step. IDK.
