If the label on the battery days 18650 2900mah and says nothing about high discharge how can you tell the difference between the 18650b 2900mah and 18650pf 2900mah? Is there a test you can do?
Thank you
Got a picture?
I would guess if it’s not properly labeled then it would be a fake, just a guess though.
Panasonic NCR18650PF cells are green and clearly marked “NCR18650PF” while regular Panasonic 2900mah cells are grey and marked “NCR18650” only.
LumenHound wrote the correct informations.
Here is a little picture, which shows some different Panasonic batteries. The 2900PF have a similar lime color. There are also the Panasonic 2900PD (with 10A high drain on the market, which are the forerunner of the 18650PF) with the same color.
