Howdy!
Howdy BLF gang!
I’m ECHO and I wanted to say hello. I’m a young environmental engineer (I know, wrong EE for here so go easy on me) and I’ve been lurking for a while trying to absorb as much knowledge as I can. Not sure it worked, but I’m ready to dive in!
My primary interest lies in motorcycle auxiliary lighting as, with only a few exceptions, our headlights are laughably pathetic. I happen to live in north central Nevada (USA) so we’ve got pleeeeeennty of wide open off-road or dirt-road spaces that just eat your light. I’ve noticed though that most of the LED lights folks seem to be using are high CCT (5000K+, often in the mid 6000K range) and low CRI which seems odd to me given that off-road the ground tends to be much more stilted towards the warmer end of the spectrum. So the lights I usually see give the terrain a weird, flat, sort of low-contrast look that I don’t particularly find conducive to good vision.
It also seems that most of the LED lights out there brag of 20-50K hour lifespans since they’re only pushing the LEDs at their rate max (5W on XP-G’s, 10W on XM-L’s and -L2’s). But when you think about it, most of us ride maybe a thousand hours a year and most of that time isn’t at night. I’d rather push the buggers harder and live with an L70 of <5000 hours since I don’t think I even clock up 500 hrs in a year and I’m sure I’ll replace those more than once a decade.
So, long term goal would be to shoehorn some 3000-4000K high CRI XHP50’s into some of the better lights out there right now running XM-L2’s. A good example would be the Vision X Optimus round (good in this case for it’s sizable optics). But I think I’m getting a head of myself as I have exactly no experience in this field. To work on the kind of skills I’ll need, I’ve ordered up a set (one spot, one flood) of Illumination Supply’s 2X2 light pods that use XB-D’s with the idea to take them apart and see whether swapping in XB-H’s and pushing the drivers harder will be possible. I plan to start a teardown/mod thread on that and hopefully I don’t get myself too far in over my head.
Any suggestions on a how best to remove the XB-D’s and replace them with XB-H’s? Also, I’m looking for some suggestions on a good started soldering iron/hot air gun and associated supplies (flux, reflowable solder paste, etc.).
If you’ve read through this far, thank you very much and I look forward to hearing your thoughts! Take care.
Sincerely,
ECHO
It's a pleasure to know you, ECHO!
Welcome to BLF!
…better put a dust cover on that ’bike, you won’t be riding it much from now on! :wink:
I’m sorry but the first thing that always comes to mind when I hear Elko Nevada is brothels. :smiley: Welcome to BLF ECHO!
We do have brothels here, but you don’t really notice day-to-day. They pretty much keep to themselves and it’s just a neighborhood of town you don’t go to unless that’s what you’re looking for. I thought when I moved here that it was going to be weird, but it’s pretty much a non-issue and now I wonder if other places wouldn’t be better off going the same route. It isn’t like that sort of thing doesn’t happen elsewhere, it’s just pushed into the shadows. At least here it’s somewhat regulated?
ECHO
Howdy!
:beer:
Howdy!
Welcome to the BLF :slight_smile:
Welcome aboard! You may have to start another topic asking for help with the lights you’ve talked about- people who could help you are not likely to look into a howdy or I’m new type of topic- good luck and enjoy!
Welcome to BLF.
Welcome to the forum. I hope you have a good time here.
HowDe,
I picked up a less then $20 Soldering iron I think mid wattage (heck I can even re-flow an emitter on it, not with it, but on it). A big tub of flux hard to have too much, easy to have too little. Thin solder wire (it is rosin core also) you can always add more solder but some times you can have too much, so thinner is easier to control.
:slight_smile:
