Specification:
1.Utilize CREE XML2 U4 LED with lifespan up to 50,000 hours burn time
2.Powered by one 18650 battery and two CR123A/16340 batteries(can’t be charged directly with 2 16340 batteries)
3.Avant-garde design of main light and secondary lights for widely use(Patented)
4.Mechanical rotating bezel design for multi-colored LEDs changing(Patented)
5.Digitally regulated output maintains constant brightness, reverse polarity protection from improper battery installation
6.Maximum 600lumens with beam distance up to 100 meters and 38 hours runtime
7.Secondary multi-colored LEDs are for widely use with maximum runtime over 45 hours
8.Additional warning and strobe light function to meet your outdoor safetly requirement
9.Quiet noise click button switch for power on/off and light level output control
10.Made of durable high-grade aluminum with premium Type III hard-anodized anti-abrasive finish
11.Lightest-weight (108g battery excluded) and compact appearance design(size 76x43x32mm) to make it very easy to carry
Product Parameter:
Products detailes:
Main lights+3 x secondary lights design(Patented),main light is for throwing long distance beam,secondary lights are for short distance with widely use
2.Compact and smart housing design can be rotated wide range up to 100 degrees with one hand operation
3.Main light: 600lumens maximum, 100 meters beam distance, over 38 hours runtime
4.Rotating bezel design for multi-colored LEDs changing(Patented)
Secondary lights:80 lumens maximum, over 45 hours runtime
5.Secondary multi-colored LEDs design meets outdoor widely use
White light:close distance lighting, general outdoor use and reading
Red light: safty warning, hunting and blood track
Green/Blue light: signal light, atmosphere light, photo back up light and hunting
6.No noise click button switch design
Power on/off; control multi-brightness and different operation functions output
Warning mode with double click; Strobe mode with long press
7.Micro-USB waterproof charging plug, the indicator is red when it is charging and green when the battery is full.
Please note it can’t be charging directly with two 16340 batteries in it.
8.Optional accessories: Angryfox battery, charging cable
Angryfox HR06 is the newest and unique headlamp in the market, the features are operated by the mechanical structure.
Interesting, but I think the basic headband strap that you show is not enough, IMO it needs to have a 3-strap headband. It is a fairly heavy headlamp at 108g - even skilhunt H03 at 44g is more comfortable with a 3-strap band.
I agree that there is little need for 1000Lm in a headlamp, that many lumens mounted to your face produces heat, and more importantly too much glare. I never use any of my headlamps in Turbo modes, fwiw. I guess it is OK to have that mode available if you really want to take off the headlamp and just use it as a 1000Lm flashlight, but even then - a flashlight would work better.
