I'm assuming others here have bought and installed these LED light strips around their home...
I recently purchased an LED light strip from FastTech, to use as an under-cabinet light in the kitchen.
I purchased this strand from FastTech:
5m, Warm-White 300-count 5050 emitters, 72W/Roll:
https://www.fasttech.com/p/1268303
Based on the specification of 72Watts/roll @ 12v = 6A, I purchased this 10A 12V PSU to use with the LED strip:
https://www.fasttech.com/p/1270307
Now, when I connect the strip to the power supply, it lights up, but my multimeter is only showing ~1.4A through the circuit. Also, when I check the output voltage under load, the voltage is dropping to ~10.3V! There is a voltage adjustment screw on the power supply that will raise the output voltage while unloaded, but the 10.3 voltage reading under load is at maximum.
These values give me a total wattage of ~14.5W, about 5 times less than spec.
Further reading shows that a 5050SMD is rated at 192mW: at full power, the LEDs alone should be consuming a max of ~57W.
- Am I missing something here?
- Are the specifications for the strip incorrect?
- Is my power-supply under-performing?
- Is the resistance of the traces on the 5m/16ft strand of lights resulting in a severe voltage drop?
- Should I connect the power supply to BOTH ends of the LED light strip, or even break the strip (As it will be cut for installation) and connect power to both ends of each section?
Ultimately, my plan is to mount the LED strips onto leightweight aluminum strips. The aluminum strips would be cut to length, and then mounted via screws to the underside of the cabinets to illuminate the countertops. The aluminum should be a cleaner surface for the LED strips to mount on, while providing a degree of heat sinking for the LEDs.
Overall, I really like the light produced by these strips, I've held them in place under the counter and they produce a good amount of light. I may purchase a second strip to install as well, and then wire them separately so you can power a single strand for accent lighting or both for an ultra-bright workspace light.
If anyone has any thoughts or experience using these light strips, feel free to chime in!
