Sorry I had to copy and paste the whole page I couldnt figure out how to get only thebparagraphd I wanted but youll laugh at some of these claims:Skip to content
FREE SHIPPING SPECIAL - FREE STANDARD SHIPPING WITHIN THE USA WITH ANY PURCHASE OF $100 OR MORE* - USE PROMO CODE FREESHIP100
Gift Cards
MF Tactical
NAVIGATION
866-9-FLASHLIGHT
MF Tactical StingRay – 2700 Lumens Max 4 Mode
Home / 1200-4800 Lumens Max Tactical Flashlights / MF Tactical StingRay – 2700 Lumens Max 4 Mode
StingRay
StingRayStingRayStingRayStingRayStingRayStingRaystingray.4
4.82 out of 5 based on 11 customer ratings (11 customer reviews)
$185.99
The new and vastly improved MF Tactical StingRay with an electronically activated switch sets the new standard in power and quality for a mid-sized high power tactical flashlight.
In stock
Select Battery/Charger Package
The StingRay runs optimally on three 18650 batteries, so you can choose a package with three batteries or six batteries and either a 4-way AC/DC Intellicharger or the more advanced 4-way AC/DC LCD DigiCharger. The flashlight does not come with batteries or charger unless you add a package below.
Add Custom Ballistic Nylon Holster
ADD TO CART
SKU: StingRay
Category: 1200-4800 Lumens Max Tactical Flashlights
Description Reviews (11)
PRODUCT DESCRIPTION
After a lengthy research and development process intended to make the next MF Tactical flashlight the most technologically advanced tactical flashlight we have ever built, we are extremely proud to introduce the new and vastly upgraded 4-mode MF Tactical Stingray. Like all of our flashlights, the Stingray is built out of solid military grade aluminum and is waterproof to IPX-6 standards. This professional grade tactical LED flashlight was designed in the USA and built to the highest quality standards to insure years of reliable service. The new Stingray, like its predecessor, still runs on three high voltage rechargeable 18650 li-ion batteries (sold separately) that enable this beauty’s three highly efficient Cree® XM-L T5 LED emitters to have the capability of an utterly astounding 2700 max lumens of pure white light. You also have the option of removing the 3rd battery tube and running your Stingray on just 2 batteries (with reduced runtime), which reduces your 13″ long flashlight to a more compact 10-1/2″ length if overall size is an issue.
During the design process of the new MF Tactical Stingray, much of our engineering time was devoted to taking all of our experience and knowledge in building great tactical flashlights and designing the absolutely best switch for use on a high end flashlight such as the Stingray. Once you hold this flashlight in your hand and switch it on for the first time, you will agree that we have absolutely nailed it. Inspired by the simple and intuitive switch found on the iPhone®, the new electronically actuated stainless steel switch on the Stingray is by far the finest we have ever designed and manufactured. And function flows from design: just press once to turn the light on high. Then, simply hold down the switch to cycle through the medium and low modes and release when you have reached your desired mode. Switch to our blinding tactical instant access fast strobe mode from any other mode in an instant with a quick double-click of the button. And since the Stingray has mode memory, it automatically returns to the last mode selected next time you turn it on. It has by far the most useful and intuitive flashlight switch on the market anywhere (patent pending)!
The three highly efficient Cree T5 emitters used on the Stingray are so efficient that we were able to engineer this flashlight to run for up to 2 hours on high on a full charge and an incredible 12 hours on low. The thought and hard work that went into the MF Tactical Stingray has produced a tactical flashlight vastly superior to any competitor’s product in this price range. We challenge you to find any flashlight sold by any of our competitors for less than $300 that has even half the power, quality and attention to detail of the Stingray. You will not find anything that comes close, because the Stingray gives you more of everything that a professional user or just a plain old enthusiast (i.e., “flashlight freak”) wants without the $500+ price tag you might expect.
By integrating the anti-roll feature directly into the tail cap design, we were able to eliminate the need for a cumbersome protruding anti-roll ring. Plus, this sleeker design makes it easier to holster your MF Tactical Stingray in its accessory belt ring holster. And what high end tactical flashlight would be complete without the protection and durability that you only get with hard military grade III annonization, which protects your professional grade light from wear and the elements. Finally, integrating an SMO or smooth reflector into the design of the Stingray ensures that you get both the benefit of a bright and tightly focused center beam combined with massive spill to light up wide areas in your path.
MF Tactical is a US company based in New Jersey that designs and builds high quality tactical LED flashlights that outperform and sell for less than inferior models offered by the larger flashlight manufacturers. Every MF Tactical flashlight comes with a full one year warranty (see Terms and Conditions for details) and the high level of personalized customer service that keeps our customers coming back year after year.
At only about 13″ in length and 1-1/2 lbs. in weight without batteries, the Stingray is an amazing powerhouse of a flashlight that will easily satisfy the needs of our devoted flashlight freak fans. The solid and incredibly well built flashlight body crowned with an aluminum “attack bezel” can serve as an effective tactial “deterrent” as well as an emergency glass breaker Plus, by designing the bottom of the tail cap to be flat enough to “tail stand” the flashlight, your Stingray can also serve as a powerful room light in the event of a power outage.
Our newly designed electronically actuated switch is a masterpiece of engineering and the starring feature of the Stingray.
The Stingray comes to you packed safe and secure in a custom gift box.
The output of the Stingray is truly magnificent. The Stingray is the only source of light in this photo.
HERE ARE THE SPECS FOR THE MF TACTICAL STINGRAY:
Brand: MF Tactical
Model: Stingray
Emitter Brand/Type: Cree
Emitter BIN: XM-L-T5
Color BIN: White
Total Emitters: 3
Battery Configurations: Powered by 2x or 3x 18650 protected li-ion rechargeable batteries (sold separately).
Voltage Input: 5~21V
Switch Type: Electronically Actuated Switch
Switch Location: Side
Modes: 4 Modes Controlled by main button
Mode Memory: Circuitry Features Mode Memory
Mode Arrangement: High, Medium. Low and Direct Access Fast Strobe
Working Current: 2.6 amp Total Output, Digitally Regulated
Brightness on Various Modes: 2700 lumens max on high
1000 lumens max on medium
450 lumens max on low
Run Times per Charge: Approx 2 hrs on high
Approx 2.25 hrs on medium
Approx 12 hrs on low
(estimates are with 3×2600 mAh batteries)
Range: 210+ yards
Water Resistance Standard: IPX-7. Protected against water penetration at depth up to 1 meter.
Materials: T6061 Aircraft Aluminum Alloy
Finish: HA III military Grade Hard Anodized
Lens: Hardened ultra-clear mineral glass with anti-reflective coating. Comes with spare lens in box.
Reflector: Smooth Aluminum/SMO Reflector
Weight (w/o batteries): 1 lb, 8 oz
Length: 13.125” with 3rd battery tube; 10.375″ without
Diameter at head: 2.8”
Diameter at body: 1.0″
Diameter at mounting pt: 0.875”
- Offer cannot be combined with any other promo or applied to prior purchases, and code MUST be entered in cart at time of order to receive free shipping.
Copyright © 2015 MonsterFlashlight.com. All rights
X
