Yeah, that sounds weird, but what I’m looking for is a light that would be easy to clean if dropped in literal filth. (1-mode on/off is fine if not preferable.)
Think of a plumber who carries a light and drops it down a septic tank or something. It can be washed off, but there’d for sure be too many nooks and crannies for filth to get trapped, and you don’t want residual stank or contamination from it later on, so the idea is to minimise if not eliminate anything that could trap the aforementioned filth.
Knurling would be a filth-magnet, trapping everything in it, so minimal to preferably no knurling would be ideal.
Threaded junctions between body and head or body and tail, of course, would trap some filth, and would need disassembly to properly clean out thoroughly.
Switch-boots would be another point where filth would be trapped. Even if waterproof to prevent actual ingress, trapped filth should be kept to a minimum.
Obvious answer would be a dive-light, which again prevents actual ingress, but filth can be trapped, even under a magnetic button.
So… minimum number of “pieces” would be, preferably, a light without a tailcap, sort of like an old AAA twisty, eg, a Manker Boney or Glaree E03 or any other AAA twisty, but there’s that joint that necessarily is “opened” (untwisted) when the light’s off.
Charging the cell means either a usb port (bad) or having to open it up. So contact charging would be preferable, like those magnetic stick-on chargers.
Still, the switch would be an issue. Magnetic would be good, but wondering what kind of actuator would not attract and hold filth.
Any ideas? :laughing:
