Hi all, looking for some insight as a new member if possible. I just purchased an Imalent MR90. I seem to be having charging issues though. The red and green LEDs are both blinking when plugged in, not staying either solid red for charging, or solid green for charged.
The charger I received is a European 2 pin, but I am using an adaptor to 3 pin as I am in Ireland.
Anyone know why it is blinking red / green, I cannot see anything in the manual, or on the Imalent website.
Is the battery tube fully tightened? Does the light turn on? Blinking in two colors is usually an error condition. The charger is integrated in the flashlight, so if it is malfunctioning you need to replace the flashlight.
This light is far, far away from having a tail switch.
Yeah the tube is fully closed,and the light does turn on. The battery came charged, and I have used it, but the charge is dropping now as it won’t go into turbo etc.
I emailed Imalent support, but haven’t heard anything back yet.
Just wondering if others have experienced anything similar on here.
The very first time I plugged it in they started blinking. It’s only when I read the instructions I realised they should be solid colours when charging.
This is strange because the battery would not have come charged. They typically ship batteries at storage voltage which would not be usable with a powerful light like this.
My MS18 does this sometimes if I leave it plugged in for too long (plug it in then fall asleep lol). Have you tried disconnecting the battery and charging it solo? Or plug it in then turn it on turbo and see if it goes solid red?
If you can afford this light you can probably afford a cheap digital multimeter from Walmart or something, too.
Should be around 6 or 7 bucks, but allows you to measure Voltage accurately, probes are included.
I was thinking if perhaps your battery was discharged too far and the charging circuitry refuses to charge it because of it.
This is possible, but you can’t measure the Voltage of the cell w/o a meter.
So I left the light plugged in all last night and it actually charged back up a bit. Doesn’t look like it fully did though. It’s like it starts charging, then trips out, starts charging, then trips…
