Me too. There is just little choice so far, and the Acebeam and Olight are fairly pricey. Klarus can be had for a lot less, but to me appears mehhh.
A slightly more expensive emitter and a boost driver compared to an XM-L variant; these lights should be much cheaper in my opinion.
DN70 is indeed interesting, and you know what kind of discounts are realistic with Imalent…
How many watts input must a flashlight have to output 16000lm with triple XHP70?
If 16000lm is the OTF lumen ouput then 18400 bulb lumens are needed. So that means 6130lm per LED, so that is around 10A at 7.5V = 75W*3 = 225W output. Add 8% losses to figure out the input, that is 243W.
But then how can 4*18650 do 243W?
That’s 60W per cell, divided by about 4V equals 15A. Can be done theoretically, but most likely is not going to happen here. The included cells are 30Q according to Finnish site. I’d be happy if it pumped out 10000 lumens.
Dangit, there goes my calculation too. But, the efficacy of 4 emitters is higher than 3 emitters, so it’ less than 15A per cell you need…
Anyhow, I don’t think Imalent is even going to deliver 16000 led lumens…
Edit:
FYI, I asked Imalent: DT70 and DT35 have 4P cell configuration.
Of course. Just ball park figures; easier to calculate. Just like 3 or 4 emitters, meh, it’s about the same. So the conclusion remains: verrrrry unlikely.
Maybe they really did it like 220W input for 30seconds, then drop to 4000lm (25%) and due to low voltage and rapid high discharge no more 16000lm at all after that (literally impossible).
Since with the new ANSI runtimes that would be totally normal.
Surely is possible, just for 30sec total possible runtime from 4*18650, after all a pull of 220W from max 40W available (lets not even mention the 2.5V cells)
Besides I am assuming all max efficiency and all, reality may be different.
