I was testing the new MiBoxer C4-12 charger with some of my batteries (18650s, AAA, AA).
I was VERY SURPRISED when I noticed the charger indicated 4.48v "Full" reading on my precious INR18650-30Q (as this is the only 18650 that Banggood ever shipped to me -- it was bought with the BLF A6 -- I pay the BLF A6 to get the battery shipped to my country, bare batteries cannot be shipped). Fortunately, I think it was only about 30 minutes or so when I placed the INR18650-30Q (the 30Q was around 4.10v or so when I placed in the charger -- I was testing the new charger).
At first, I thought maybe it's just the display malfunctioning for the MiBoxer C4-12, but then I tested with my multi-meter and got surprised (the MiBoxer C4-12 display is reading the voltage correctly!), my MS8229 multi-meter reads 4.52v (based on comparing with other meters, I've noted that my MS8229 multi-meter tends to have a higher reading of around 0.02-0.03v for batteries DC voltage range). In any case, the INR18650-30Q had been severely overcharged (the battery was not hot or anything though, when I touched it).
My immediate thought was to discharge the battery first to safe levels, I don't think my other analyzng chargers can discharge this severely-overcharged battery ("check battery voltage"), so I got my EBD-USB+ and connected to a battery holder and used that to discharge the battery, at first I used a 0.30A discharge (voltage drops very slowly), so I increased to 0.50A then to 1.0A discharge rate). After discharging for a short while, I stopped to check the unloaded voltage 4.31v, 108mAh has been discharged from the INR18650-30Q (from 4.48v --> 4.31v).
(after discharging 108mAh, it now reads 4.31v on the MS8229 -- as the MS8229 over-reads around 0.02v, true voltage might still be 4.29v)
I connected again to the EBD-USB+ meter and continued discharging at 1.0A current load, after 262mAh capacity was discharged, took out the battery which now read a safer voltage of 4.08v.
Question is: has my INR18650-30Q been severely damaged with the severe overcharge? This is one of my few INR18650-30Qs (several batteries I ordered from AliExpress were cancelled due to shipping, so I have a really hard time getting batteries...).
Also, is it "safe" to still use this INR18650-30Q? Or should I let it rest awhile and then due some Charge-Discharge cycles at a low current to "recondition" (if this applies) the battery?
