I am working on a flashlight driver design that will include a charge capability for 1-4 cells. I am considering how to implement reverse voltage protection for improper cell insertion. All battery charging ICs I am finding do not include this as a feature the best I can tell. The cell gets connected to the BAT pin or some similar name, and the maximum reverse voltage on such pins is generally less in magnitude than –1V. A simple approach is to put a schottky diode in series, and many chips have the capability of remote sensing to allow for this.
Any other ideas here? What control chip would you recommend? I am looking for something I can hand solder. I don’t have a hot air gun and am not looking to get that complicated. I realize this may cause it to be a bit bigger due to needing to have an external switch.
