Good Morning Everyone
I’ve been having tons of fun searching up and down to sort this concept out…
On my third sphere design…
First two were PVC traps, and very similar to one another. One was BaSO4 coated and the other was not. I did not get consistent numbers as the lumens climbed. I suspect that calibrating under 1000 lumens, and using a multiplier derived there, loses it’s accuracy when the light output is increased substantially. For example, I calibrated using three brand-name lights. An olight M2R warrior, olight S10r baton iii, and a nitecore p12. All going off manufacturer’s ratings, at 30s timed, and figuring a multiplier with that. Using that same multiplier on a higher powered light seems to give me substantially lower numbers than expected. By higher powered, I am referencing MT09R, L6 XHP70.2 FET, D4, Q8, and the likes.
I’ve even calibrated using diffusing sheets, smiliar to TA’s sphere design, and removed the multi alltogether, reading lux equal to expected lumens. Still reads lower than expected with higher power levels.
At this point, i’ve given up on my plumbing trap designs…
This third sphere, I went all out and trying to make it as consistent as possible. I am wondering if it is reasonable to expect a single multiplier to be applicable to all lights and all power levels (ML, L, M, H, Turbo, etc.).
3rd sphere build:
17” bouncy ball from walmart
paper mache about 10 layers of 1-2” wide strips of newsprint
1 outer layer of fiberglass fabric, cut into strips similar to the paper mache (using fiberglass resin for hardness)
cut the ball in half
added 4 sets of tabs on the outside to align all 4 sides when reassembling
added 4 L brackets to clamp the ball back together and secure with bolts and wingnuts
two ports 90 degrees off (one for input and one for output)
painted internally with 3-4 layers of untinted white paint, then 3 layers of 50% BaSO4 with the white paint
all centering rings also painted with BaSO4
So when I use my meter (Dr. meter) and read the 30s measurements from my reference lights, I get a large range of multipliers for each light. Somewhere in the range of 0.26 to 0.17. I’ll post my detailed numbers when i get home tonight. Typing this on a break at work at the moment.
I’ll snap pics of the new setup as well for critique, and post them here.
My main question is, can I use one multiplier to measure all lights? High and low outputs? Ranging from moonlight mode to 20k+ lumens? Is this a reasonble expectation? Do i need to derive a log scale to vary the multi based on the lux value?
As a side note, I haven’t calculated the port to internal sphere surface ratio. I am guessing this might have a little to do with the variations too, as the lens diameter of the mt09r is significantly larger than the p12 and olights. I haven’t really delved into what this should do to my multi. In that case, i’m getting 907 square inches internal (from 8.5” inner radius), minus the ports. Gotta calculate the port diameters tonight too.
Preemptive thanks for the ideas and discussion.
