Hello everyone,
I had an interesting discussion with Wurkkos flashlights today, sharing some first ideas about developing a flashlight with colorful beam (RGBW). Since there are many flashlights with colorful beams out there already, I suggested to start with a thread, gathering and collating the best ideas to make this one special and in every possible way as good as it gets.
Please feel free to post your ideas and your requirements for the ultimate multicolor flashlight.
Some personal initial thoughts:
This initial post is work-in-progress, i.e. I will supplement further ideas incl. pictures later on.
1. Host size
Personally, I think a single-cell flashlight is best for a flashlight with multiple colors. Power consumption and heat dissipation is usually not that much of a problem as you face with powerhouse flashlights like FW3A or D4. A good host in terms of size and appearance might be something like Sofirn's SD05, using the new 21700 battery size. However, the magnetic control ring might be a challenge with four different colors and different brightness levels.
2. Emitters, Reflectors/Optics
This is actually a crucial point. Today, we have the luxury to choose between four independent LEDs for each color (e.g. XP-E2, SST-10, Osram Ostar Projection Compact Q8WP) or a single LED with four independent die areas (RGBW LED like Osram Stage S2WP or XP-E color). As I have seen on the Fitorch MR35, a single reflector and multiple LEDs aligned in it do not result in a nice looking beam. You always have the trade off with donutholes or awkward beam shapes.
My assumptions for a light with multiple single-color LEDs:
- each LED needs to have its own reflector "cone" (see Sofirn Q8 for example) to avoid donutholes/artifacts in the beam
- each reflector needs to be correctly aligned to form a uniform beamshape
- advantages: more options for powerful emitters like Osram's Q8WP with up to 5A current and > 500lm output
- disadvantages: the head diameter will significantly increase due to the necessity of a quadruple reflector housing
alternative: 1062x quadruple Carclo frosty or pebble optic (less throw but smooth beam pattern) or mule design
My assumptions for a TIR light with one multicolor LED:
- one single LED TIR optic for concentrated but evenly shaped light distribution (see Fireflies E01)
- OSRAM OSTAR Stage LE RTDUW S2WP might be one of the best multicolor LEDs
- advantages: small head size, less heat dissipation
- disadvantages: less powerful and less choice of special wavelenghts (e.g. 660nm deep red), possibly more expensive for emitter costs
