I just saw this :
https://omglumens.com/DEFT-edc.php
Obviously it's not a budget light :) but it's interesting never the less. I haven't seen a review of it yet but I'm curious as to how much further it throws than something I could (and have) come up with.
By that I mean, I know it is much better that what I've done but anyone who takes a brighter emitter and an aspheric lens and puts the two together in a certain size range will get decent throw.
The DEFT EDC will get much better throw due to overdriving the emitter and much better heatsinking, etc. It's selling for $199 I think. If you take a P60 host and a 28mm aspheric and use a XR-E R2 (they are using XP-C Q4) you can do it for let us say $30.
I'm wondering how much further the throw is when you do everything right (DEFT EDC) vs doing it the easy way. If you get throw of 300 feet one way and 400 feet the other way it's worth it to some (not me however). If it's 300 feet the easy way and 900 feet the best way then it's worth it perhaps if you can afford the money for such a specialty light.
I think I saw that is was supposed to output about 40,000 lux at one meter. I'm trying to think of some similar known numbers from throwers that have been rated in the past. I have a HS-802 and also made a 30 mm aspheric however mine was driven at 700mA and the EDC is a XP-C driven at 1.4A.
I thought I remembered seeing some figures that the HS-802 could be in the 30,000 lux range. Since an aspheric is more efficient but mine had a smaller diameter then maybe it would be logical to assume upper 20k at least?
So perhaps we are talking about the premium for doing it the very best way over the way anyone could do it without even having to solder might be 10k lux?
So does this mean it would throw 25% further than the cheap version or 50% further given the squaring law that applies here. Where is Dr. Jones when you need him :) Optical math is not my strength.
Anyone who can clear this up please step forward :)
All I'm really trying to do is compare the new thrower with known existing throwers of the past and in particular one's that I own so that I get a good idea of how much improvement one can get just by using the best technology.
The interesting thing with the EDC is that it's not getting throw by using a reflector that's larger than a P60 style light would use.
