Depending on the driver this looks like it could be quite a thrower, its a little hard to tell how deep the reflector is though.
The tail looks like it has square threads and looks like it can tail stand.
Appears to have a pressed in lens though and I have no idea if the reflector is plastic or aluminum and if the gold heat sink is functional or just copying the style of other lights.
Need major reconstruction for it to throw anything. To begin, it's not CREE. Then, pill is hollow plastic. Plastic everything, reflector, lens, pill. And they're press-fit from front, it's a pain to remove internals without damage.
I have lots of these, I think more than 10 probably :)
I don't have the exact one like your post but I had two or three very similar looking one. But despite having many shapes, one thing about them is that they all share the same characteristics as my post above.
So quite likely this one will not stray too far from the tree.
I had that exact same light. It was advertised as AA but arrived as AAA. Not a bad light, but not very moddable. It didn’t have a Cree R5 either. It pulled about 300 mA at the tail cap if I remember right. Here is the thread Ultrafire 705 from ebay $3.50
I measured around .300mA. I´m planning to put an Osram led in it. Maybe a driver swap too.
Its a little odd that the lens, led and driver goes in from the front.
Thats true! Or 1 of the best showers you can get for even less money. Buy 2 and mod one with an XM-L and a 3 amps driver and an OP reflector and you get a wall of light.
