Hello BLF friends,
Glad to share with you ACEBEAM’s latest D20 2.0, Specifically Engineered for Underwater Illumination!
Key Features:
- Powered by the cutting-edge Luminus SFT40 LED, offering unparalleled penetration with a maximum output of 2200 lumens and a throw distance of up to 500 meters!
- Utilizes a single 21700 rechargeable lithium-ion battery for reliable and enduring power supply!
- Unique 9-degree beam angle provides exceptional focus, ensuring no blind spots during your deep-sea adventures!
- Engineered with a professional pressure-resistant waterproof design, featuring specially crafted dual-layer waterproof seals, passing rigorous 100-meter waterproof tests with flying colors, allowing diving depths of up to 200 meters!
- Equipped with SUS316 stainless steel side switch for enhanced corrosion resistance, perfectly suited for the harsh underwater environment!
- Features ultra-transparent toughened glass lens with anti-reflective coating, achieving an incredible light transmission rate of 98.3%, illuminating the underwater world with crystal clarity!
- Battery indicator function allows you to monitor power levels for added diving safety!
- Double-coated toughened glass withstands high water pressure, ensuring robust reliability!
- Constructed from high-strength aerospace-grade aluminum, with a next-generation diamond-level corrosion-resistant oxidation surface treatment, providing a denser and thicker protective layer than standard military-grade III oxidation, effectively resisting corrosion from seawater!
Versatile Applications:
- Ideal for divers and underwater photographers as a backup light
- Perfect for underwater rescue, fishing, salvage operations
- Suitable for underwater archaeology, cave exploration, wreck inspection
- Illuminate marine life from a distance, indulge in the thrill of underwater exploration!
Surprise Benefits:
- Underwater photographers can use it to set up a movie-studio-like scene
- It is incredibly difficult for water to enter into the device
- Use it to discover how the underwater world is a dynamic, lively space
- 5.5-hour ultra-long runtime ensures you can finish an underwater mission with ease
- One of the best waterproof flashlights to help you with insufficient lighting situations.
Learn more: https://www.acebeam.com/d20-v2
