Is an LDCH LD-34a capable of driving an MT-G2?
As I couldn’t find a clear answer in several topics, here is my short question:
Is the L4’s built in driver capable of driving an MT-G2?
At the moment I’m using a C8 host, but 2*18350 is a bit on the short side in regards of runtime…
The L4 came to my mind, because that way I could easily swap the reflector setup and use two 18650s.
Thanks in advance!
Julian
/edit: Topic changed because of some nice, but not purposeful answers.
Extension tube for C8:
https://www.fasttech.com/products/0/10007058/1575200-aluminum-alloy-extension-tube-for-1-18650-c8-led
Good idea, but I’m very sure, that one won’t fit the Thorfire C8.
So, ideas on the LD-34A anybody?
The extension tube indeed doesn’t fit the Thorfire.
Don’t know about the L4 but the Ultrafire F13 with 2x 26350 is a good alternative with better runtime and heat dissipation.
Nice idea, too.
But I don’t want to buy new batteries just for that one.
I think I will change the topic a bit…
The L4 have a extension tube as well. I’m also interested if the stock driver of L4 can run a 6V LED. If it can, I want to try putting a XHP50 in it.
I don’t know, but apparently the BTU shocker uses a driver by the same name, LD-34, and it has three XMLs in series with three 18650s in series.
