simple answer: one or more xmls, so min 3v out, 3amp. for xml color one amp. any input voltage will work. I am not picky.
I was thinking running an xml(s) or xml color(s) as a semi- portable room flooder.
with the xml color, i need one driver for each die, at about one amp. I may want to daisy-chain more of them together for more brighness (max ~4, so about 3-14v out).
same for regular xml except 3 amps. I would Ideally like to be able to run the whole setup from whatever voltage is available, or a battery pack.
I would much prefer not, because I want to crank it down to sub lumen levels, and don’t want to see any pwm at all. even if it is a high frequency. (just my nitpicking). I also want the option of using flex sensors, photoresistors, temp sensors, and the like to control it should I want to.
on the flipside, if I decide to ever control any rgbw project with a microcontroller, I might be able to use the pwm output with a big enough capacitor to smooth it out to a sudo-analog level, giving me more control over the color mixing.
