Is this head lamp overkill?
I mean would it overkill anyone staring directly at it. 5,000 lumens. I think that’s lethal right? :slight_smile:
It would certainly be overkill if it was actually 5000 lumen. But it isn’t even close to that… very misleading product description actually. They make it sound like 3 x XML (which would still not be 5000 lumen) and then when you dig down a bit you see its 1 x XML and 2 x XPsomething. Realistically, given the LED are probably massively under-driven you’d be lucky to see 1000 real lumen.
lol, like kwarwick said, you’ll be lucky if you get 1000, and you will be extreamly lucky if leds do not degrade in a month. also hard to believe they are using real cree, with so much LB leds marketed as cree, i would think more likely than not you got LB there not cree
