I might be missing something but why do people mention solder points on the driver as an indication of a fake?
As far as I am aware all drivers in the S2+ with more than 4x7135’s are soldered, including the ones directly from Simon. These are review photos of a grey and and a green S2+ from Simon’s store, both appear to have soldered drivers.
Can you tell the tint?
I have doubted buying one, since the price was really low, but the adverted led was u2 1b, which afaik does not exist.
Also the image showed a green tailcap, but above post told that is is black
Because you may someday want to swap out the old driver for a modern one — if so, you should avoid soldered drivers.
It’s difficult to clean all the solder out of the threads.
If you want a driver with more than 4 chips you file some small notches in the retaining ring and screw it down.
Discussion at length with picture at:
I wish Simon was providing notched retaining rings, it’d be easy with a water jet cutter to notch them like this.
The metal is removed just from the overhanging lip, not from the part with the threads that contacts the driver when screwed down
Yes the tint u2 1b got me thinking that there is something fishy about their offer,
so I asked them about the discrepancy but they just brushed it off with their canned email reply.
Same thing with the black tailcap, they are prominently displaying a light with a green tailcap so looks to me as a blatant case of “green bait and black switch” :rage:
I realize why some people might want drivers without solder. I was puzzled as to why it seems like some people relate soldered drivers to fake lights. I thought I had seen it mentioned in previous threads and not understood the connection. If this particular light was 3x7135 and had solder points I would understand comments about solder but since this light is meant to have 6 chips the oddity would be a light without solder.
Factory notched retaining rings would be nice. It looks like they could be made pretty easily on a small cnc machine or similar, I should ask a friend if he can modify a few.
Lol, that might be a little harsh considering there was a batch of fakes not long after the red version was released.
It’s been there for weeks, if not since they put this product on. I know that because I’ve been eyeballing this light for a while now. Easy to miss though.
I saw it too and was hoping to get the black cap. The only convoy I have received with a green cap was a host. When I see the green caps on a flashlight on someone else’s site I wonder if they built it from a host.
Received mine today, the host itself it is genuine Convoy S2+ but the driver is not standard Convoy driver, although it is same basic 7135 based driver it is a bit different from other convoy lights i have/had.
Driver is labeled as FX-12 and it has different PCB and spring than the standard Nanjg 105C/105D.
I modded this light after owning it 10 min. Reflowed the stock led on noctigon board and swapped the driver for a 105c with 12 7135 chips, 8 stock + 4 380mA. Tail reading with DMM shows 4.21A with 25R.
Was it worth for the price? Yes, especially when i paid only $7.5.
