Looking for a long runtime headlamp at 500-700 lumens.
One of my hobbies (aside from flashlights) is insect photography. I tend to focus primarily on moths, and collect my specimens by running UV and Mercury Vapor lights from dusk to dawn in front of a sheet at a couple locations on my property. Due to the different activity patterns of different species, I usually check the sheets a couple times a night around midnight and 3 am.
Having both hands free to collect the specimens is absolutely necessary, and I have a few different headlamps that I rotate using between charges.
I currently own an Olight H16 Wave, an Olight H2R, and a surprisingly decent for the price Boruit RJ-5000.
The H16 is my preferred light, but the runtime on high (500 lumens) is somewhat limited. I know some people find the wave function gimmicky, but I appreciate the ease of shutting the light off completely to conserve battery.
The Boruit is a bit clunky, the UI is very simplistic, and the light is a bit on the heavy side, but the output (probably close to 500 as opposed to the advertised 5000) and runtime are both actually pretty good.
The H2R is my least used, mainly because I don’t care for the switch placement, but the output and runtime are probably the best of what I currently own.
What I am looking for in my next headlamp:
- long runtime at the 500-700 lumen range (preferably 3+ hours which would get me almost a week of use without charging) I don’t care at all about maximum output as I don’t use turbo
-switch on top of centered units, or side of right angle style lights
-high CRI is preferred, but not a necessity.
-built in charging preferred, but I have plenty of 18650s, a few 21700s, and a few 26650s if I need to remove and charge.
-no use for any blinkies or strobe, so no lights with those in the main mode cycle
Lights I am considering:
-YLP Panda 3R
-Fireflies PL47 (I’ve seen some rave reviews about the high CRI SST20 400K version, but it appears to be sold out/discontinued)
Any other suggestions or recommendations would be greatly appreciated
