I finally got my modded M6 working!
Refer back to this post: So, what do I need to mod this M6? where I asked how to mod the M6 to be a light cannon. Well, after Cereal_killer helping me out at nearly every step of the way, I got it assembled and running!
What was done:
- added wire to tail springs for lower resistance
- removed original LED star
- installed 3x XM-L2s on 16mm copper Noctigons w/18 AWG wire
- stripped out all components from original board except FETs and build solder bridges where resistors used to be
- installed driver provided/programmed by Cereal_killer with original driver running in slave mode now
- Milled out the backside of the reflector a LOT to provide clearance for the new LEDs
I was stuck on how to mount the Noctigons and nearly gave up until I re-read this post: Supfire M6 - resistor mod (Update testing XP-G2s on copper in post 59-60) but I didn’t have thermal adhesive. What I did was I put the reflector in with no LEDs and scribe a circle on the base. From there I applied a tiny amount of thermal grease, I figured the clamping force would spread it out. Then I took a tiny amount of JB Kwik to the top and bottom of each Noctigon and placed them onto the base and quickly put the reflector in, lined up the LEDs, and clamped it down for about an hour. It worked, and those LEDs aren’t going anywhere.
It’s quite bright, brighter than my very lightly modded TK-75 is currently. I don’t have any way to tell lumens but I’m pretty happy with the result. And I got really lucky in that the LEDs are positioned just so - no donut rings or odd hotspot shapes. I don’t have any in-progress pics unfortunately.
I would not recommend this as a first flashlight project. It was mine, and if it weren’t for Cereal_killer providing tons of help, I don’t know if I would have finished it before I gave up.
