I bought it from aliexpress and it goes by: JAXMAN E3 high CRI outdoor Flashlight Torch use AA alkaline or Ni-MH battery Nichia 219B series warm white (4000K)
here some pictures, dimensions and toughts
sorry not very much data, but maybe it ansvers some questions for somone
Inside box: E3 flashlight*1, O ring*2, Stainless Clip*1, Hand Strap*1, Keyring strap*1, manual (english and hieroglyph) and I think it some sort of warranty card
(battery was not included)
Here data from seller page and from user guide (comes on paper english and written in hieroglyph)
*Battery: 1*AA size battery, Alkaline or Ni-MH
*Switch: Tail switch
*Modes: Low-Middle-High,Max 200 lm. Max. current=700mA
*LED Type: Nichia 219B series High CRI led lamps, Ra=9050, Warm white (4000K) (can be obtained also Cool wihte (5700K))
*Lens: aluminium reflector, toughened mineral glass, AR coating and glowing O-ring (Like I understand manufacturer can change
glowing O-ring with non glowing if you beforehand mention it. Only cant understand why he dont say to me, that O-ring dimensions
was 17mm x 0.5mm but that says only that very hard to find exactly fitting)
*Body Material : T6 6061 Aluminum alloy CNC manufatured, Anodic Oxidation Coating >45 um.
*Tailstands: no (first ~5min standing and then starts fall)
*Price Paid: 23.20$ + 2.51$ shipping
*From: Aliexpress seller Suizhou Jaxman Electronics Co.,Ltd.
*Date Ordered: Sep. 26 2016
Lenght: ~95.4 mm
Outer diameter (head): ~19.6 mm
Inner diameter (battery tube): ~14.2 mm
Inner diameter (switch tube screw): ~18.2 mm
Switch tube lenght: ~14.1 mm
Battery tube lenght: ~51.2 mm
Head tube lenght: ~35.6 mm
Switch ring (some yellow metal) diameter: ~17.2 mm
Switch rig thickness: ~2.9 mm
Head tube inner diameter: ~17.2 mm
Driver and led lenght: ~10.7 mm
Driver and led diameter: ~12.6 mm
reflector lenght: ~12.1 mm
reflector diameter: ~12.1 mm
reflector lower hole: ~5 mm
lens diameter: ~17.1 mm
lens thickness: ~1.5 mm
lens glowing O ring diameter: ~17.2 mm
lens glowing O ring thickness: 0.5 mm
weight without clip and battery: ~44 g
clip weight: ~2 g
I measured temperature (celsius) over runtime (~1 h) with full mode
used eneloop
other setup
after 10 min
and full graph
bigger and brighter are Jaxman E3 full, smaller are Roche F12 (Cree XM-L T6-4C) low mode
I think it ~30m OK
I cant heard any sound in any mode
No PWM/pulsing so much what I can see (and through camera)
And when anybody wants pouch and clip then must count this
