I prefer shipping included in price making it “free shippibg”
I don’t mind ordering 3 things with shipping priced into it but do mind seeing three times shipping costs. Hence I select fee shipping when searching on AE.
Only a telescope and two orders for LEDs at Jaxman were with shipping last half year.
BTW I asked for the BLF discount on the LEDs via pm and message on AE. Reaction AE a blunt no and pm here no answer.
hi,dear all, I am in hospital for a week.My father was sick.
Then ,my mother-in-law was also sick yesterday night……
To be a single son,as most of Chineses born in 1980s, we want say:I am tired in now and futrue…
BG, FT, GB? I dont know. the Purchase department of them would tell us who they buy for…
We all (at least should) know that family comes first. I hope that your relatives get better and that you can find some time to un-nerve yourself.
As for the pro’s and con’s on shipping stated before: there ain’t such a thing as a free lunch.
The same goes for shipping. You’l have to pay for it: one way or another.
dear, thanks for your support and good wishes.
The plan-reproduce of population in China is a lose policy.That mades many 3 person family,parents and a single boy or girl. When the parents are old, the son or daughter will face big difficult and trouble.
I hope everything gets well. Having lived in China for 5 years when I was young I understand the struggle… Thanks for sharing your feelings with us, sometimes we assume dealing with someone overseas is like talking to a robot and everything is scripted, yet we don’t realize it is a real person just like you and me and anybody else.
Quick physical impressions: the build quality and finish is excellent with lubed trapezoid threads, anodizing was perfect and the reflector assembly was impeccable. Nearly all of my other budget lights came with at least a few tiny dust particles inside the reflector visible with the light turned on, but this M8 was surprisingly clean. I seems like it was assembled in a very clean factory.
Will try post some more details and pictures later today, but so far I’m very impressed, the overall quality is beyond the level of the X6, Convoy C8 or D80.
The head and bezel can be taken off, it’s not glued but tightened really hard. Battery slides both ways.
Ok some pics and more info:
-Out of the box it throws about 30kcd, or roughly half of the BLF SS/CU X6. I’m confident the M8 will surpass that after I go full hot rod with a FET driver, thicker wires, spring bypasses and mcpcb soldered to the pill.
-My DMM broke so I couldn’t take any measurements yet, but this driver is only 6 chips so it should be around 2.1A.
The M8 and the C8 are on both ends of the spectrum for big head 18650 lights…
It has the smallest head after the M2, even smaller than the X6
Maybe not the best pic but it shows how clean the reflector is, and the coated glass is nearly invisible. It has a green AR+AF coating on it, I’ve seen blue, purple and red but never green.
Flat top springs on both sides, supossedly gold plated. The brass pill is screwed from the rear.
Whoever designed this reflector knows his stuff, look at this beam:
The MCPCB was secured with two screws I couldn’t remove, will update with more details in the mod thread when it’s done.
I got mine in today, I’m sure that I opted for the ‘yellow’ 7A version but this one clearly is close to 5000K, I guess I got the 3C instead. I’m a bit disappointed by that.
Indeed a great beam, a very nice and clean reflector, and I like the green AR-coating. This XP-L Hi gives a bit yellow center in the hotspot, just like one of my X5 lights from the group buy (and the other with the exact same specs does not have it). This yellow hotspot center seems to be hit or miss with XP-L Hi leds, but at least it only apears when the reflector is high quality.
I like the plain low-med-high without memory that I chose, with a decent but not perfect mode spacing. I measure 24-220-700 lumen. The output is very stable; at 2.1A and current regulation that is no surprise but even with that considered he stability surprised me, the used 7135 chips must be pretty good. And I see no PWM at all, it must be high frequency: well over 10KHz.
The tail spring does not attract magnets so I assume it is the copper alloy that the advert mentions, the driver spring is a common steel spring, they did not mention that.
The throw at high setting I measure at 31 kcd, that is in line with what Will34 found. When this Jaxman M8 is seen as a host this leaves plenty room for improvement, I may like to put a dedomed XP-E2 Torch in this one
Low-med-high was one of the options that I could choose on check-out. But it has to do with the stars, on my driver the middle star is bridged, you could try that.
Thanks! soldering the middle star changed the modes to low-mid-high… much more usable now
EDIT 14/5: Replaced the driver to a DrJones’ H17F, both spring bypassed and used a more consistent thermal paste. Didn’t change the stock MCPCB so let’s hope it does fine. It now puts out ~65kcd which is 10% higher than the BLF X6v2, awesome throw for such a little light. Also because of the brighter spill the M8 is a lot more usable indoors vs a big sized C8 with XP-L HI.
The driver I took from the M8 will still work for other projects, I see that it has room for 2 more 7135s in the back so I can make this into a 2.8A driver.
Off-topic: Not sure why I’m only getting 5.2A with a Samsung 30Q where in my full size C8 I get 5.45A… probably something about the driver being soldered only on one side instead of being pressed with a ring. Using a large FET driver like the MTN-17m will certainly hit ~6A but I like the H17F so much that I’m willing to live with a lower current.
I opted for the yellow 7A as well. The box came with some QC card (which we should all totally throw away) stating so. What does your card say? The beam is completely yellow in mine.
I like it better than the Convoy M1, despite the M1’s nice matte HA-III anodizing.
Sorry for the thread necro but figured this would be the most appropriate place for this.
I will be buying an M8 probably next month and it will more than likely be the XP-L HI version.
As you all know, this is an easily moddable light so question for those who have went from stock 6x7135 to 8x7135: was it worth it?
Looking at the XP-L datasheet this +33% current increase would increase flux by ~+23. And if IF goes up so does Vf; if I calculated correctly LED wattage would go up +38.5 (not including driver inefficiencies).
So for quite a lot more heat you get very little visual difference in regards to max flux.
As I’m not an expert, what happens to max throw?
Flashlightwiki has a “light output measurement” article and if I take Jaxman test result “41000lux at 1 meter” and calculate max throw as FL-1 standard defines it (sqrt(candela/0.25)) I get 405 meters?
And if I simply add 23% to Jaxman’s test result, the throw calculation then gives 449 meters. So ~11% more throw?
Am I even in the right ballpark here?
If I am then I’m not sure if the positives outweigh the negatives for me.
