hi,dear all,those days,I was focusing on a new single 26650/18650 flashlight,the X1s. X1s is a developed model of the X1.
The out look of X1s.
and the some detail picture:
We want the X1s be a short,powerful,and solid flashlight. It should has a good waterproof,well holding feeling,and a practical tool for the user.We produce two version, the throw and the flood.
the flood version is based on XHP50 famlily lamps. we can use XHP50,XHP50.2.We now can provide the XHP50 in 4 tints, and XHP50.2 in 1 tint—–6000K coolwhite.
the throw version is based on a 3535 size LED—- XHP35 HI. and a smooth reflector.
we have 3 kinds of tint xhp35hi now.
We decide the last modes are: High 100% ,Middle 40, Low 10. and another working mode—-fast stobe at 8hz, at any mode,if the user fast click the switch in 0.2S, the flashlight will go into fast strobe mode. And once the user shut off the power and turn on again, the flashlight will go into the former mode before fast strobe.
Because in the trial production we use a different mode: H,M,L,breath strobe and fast stobe(2 fast click), so we have some trial version in flood X1s XHP50.
The driver of X1s is a boost one,so the current is some big, max. can up to 7A. so we use a larger tactical switch. This switch is some different with the other JAMXAN flashlight,
the tail switch will on when you press it lightly and locked if you press hardly. And so the mode changing orperation must be finished before you lock the switch.
As the shelf or drill,we think they are all good solutions. To choose which is only for the technical convenience.This X1s is no drill.
We have to repeat one question, the X1s is based on standard 26650/18650 battery.Any battery with a protection board maybe not well accord to X1s.There is no a standard of all repacked batteries, some are thicker,some are longer, no standard size…We promise the max OD of the battery is 26.5mm, the Max. Length is 68mm. Otherwise it will cant work.
Another probelem is, all protect battery maybe cant discharge at >6A. so if so, the 20W flood version may cant work, because it need a bigger input current.
All the 2 kind of X1s are working at the official max. power in high mode. the flood version is 20w max,and the throw version is 13w max.
As a new product, we set a 15% off. one price is including shipping fees,—-since most buyer like the price including shipping fees, I want make a try. one is without shipping fees.so the price is some different. I do like a directly thinking method,but the market is like an not directly way, then I want try it too.
Any question, pls mail me zx.bao@foxmail.com or here.
Best wishes.
