The giveaway is for TWO of the UF F-13 lights from GearBest. I have put thermal grease under the stars, changed the + wire on the driver to the second pad, bypassing the resistors and I have used the pencil trick on the driver as well. Other than that, they are stock.
There will be TWO winners drawn. Anyone who has been a member on or Before 07/01/2014 can have a chance. Your post number is your lucky number. I will use Random.org for the drawings.
The giveaway will end on 07/08/2014, sometime during that 24 hours of the 8th.
Thanks to GearBest for providing the lights.
Good luck!
Using the second + pad on the driver, bypasses the line of resistors.
