Young Man.
My neighbor got hers,
but mine are still missing,
forcing me to go legging-less.
I Demand Recompense!
. . —————— Karen.
Young Man.
. . —————— Karen.
Lightbringer:
amishbill:
Lightbringer:
We’re a friendly bunch. You can shave your head, pick up your goat-leggings, and sign over your bank accounts later. No rush.
Young Man!
I’d like to speak to your Manager.
I was PROMISED goat-leggings
Three Weeks Ago, and they’re
still not here……
. . —————— Karen.
Can you send pictures? I can give 50 points to your account. Can you check post office make sure?
Young Man.
I Demand Recompense!. . —————— Karen.
Can you send video? Please go post office check. I can give 50 75 points. Happy?
Can you send video? Please go post office check. I can give5075 points. Happy?
Young Man!
I Never Agreed for my
Goat Leggings to be outsourced
to BangGood!
I DEMAND a Second Pair,
a Complete Refund, and
the firing of someone!
. . —————— Karen.
Lightbringer:
Can you send video? Please go post office check. I can give5075 points. Happy?Young Man!
to BangGood!I DEMAND a Second Pair,
the firing of someone!. . —————— Karen.
I understand. Can you send video? Please check local post office.
This escalated quickly…
I’m in the Boston area, but it also seems there are options on places like eBay, unless that’s not a good idea. So now I know I need a size 18350 and can use a button top (there are springs on both ends of the interior). What’s left:
I can’t tell whether I should use a protected vs unprotected cell (doesn’t come with any instructions) or what mAh is optimal and available for this light. Lastly, are all of these cells rechargeable? I want to get a cradle too for whatever battery I do get.I want to thank everyone who has kindly chimed in thus far. You guys are an extremely helpful and friendly bunch. I wasn’t sure anyone was even going to bother to respond at first as all the discussions are so far beyond my question. Boy, am I pleasantly surprised.
Jennison
you can get unprotected, since the S1 will turn off before the cell gets too discharged
==they go to about 1000 mah i think
get the biggest you can afford, though if it costs $1 and claims 4000 mah, it is fake
the 18350 will probably disappoint you with its capacity no matter what so try to get the most mah
you will also see ‘max current draw’ possibly
you can;t really maximize max current, and max capacity
i would get max capacity
==li ion, yes
==you can get by with a $2 charger from ebay though others will warn against it
wle
wle
Unless I’m not interpreting the info correctly, seems like a lot of these chargers can be adjusted to accommodate different size batteries. Is that the case?
most have moveable terminals, some will not and those will most likely be for 18650
i do also recommend getting the 18650 extension tube
the mah/dollar ratio is WAY higher than 18350 cells
wle
Actually, those generic come-with chargers (Thorfire, Sofirn, etc.) are pretty decent. Simple, stoopit, but they work. Never saw one overcharge a cell or anything. (Well, not yet.)
they may not be super fast but they usually are fast enough, and safe
one thing though is, they may use too high a rate for smaller batteries, especially if it is not adjustable
that would shorten their life some, but would charge them faster
wle
Thank you, You guys are all mentioning an “extension tube,” presumably so I can use the more common and functional 18650. Where does one buy an extension tube?
red or blue
Ohhhhhh, this is awesome, and cheap too!
I’m going to order one today. When it comes in 8 months, I’ll get an 18650 battery. Seriously, thank you. I’ve ordered a black one.
Jennison
aliexpress can take a long time to deliver, but you have your current version to play with
amazon has the tubes too, but they are $12
wle
Naw, that’s fine. I can wait.
you can also use CR123A cells instead of 18350 - they just won’t last long or have a very high output…
wle
it seemed like the same thing, after i put 2 links in there, i thought they looked mostly alike
wle
Thanks!
typically an 18650 will have 2500-3500 mah
best 18350 will be 1100, typically only 800
a couple minutes of ‘turbo’, then it isn;t doing over 200 lumens til a recharge
out of 8 levels, it will be 4 or 5
as far as using it exclusively as an 18650 light - that is fine, but there are other 18650 lights that are much smaller
the S1 isn;t really pocket size, to me
wle
That is good to know. Thanks.
